the saga of the rear brake line
I was just about to post the very same question. Is this the line you are talking about Superdave?
And does the rotted spot look like the middle line in this picture where the braiding meets the solid line?
I just replaced the entire rear line (except for the braided line) to the calipers after it rotted through half way back. Now I just need to replace the fancy braided line before it blows too. I just want to verify the P/N above is for this tube.
Of course, it would have been nice to do the whole job at once, but I needed the truck back together quick and I didn't have time to track this part down at the time. Now it's time to finish the job.
Thanks.
Thanks.
thats the one !!! the exact same spot as mine
GAAA! Rotten brake lines scare the crud out of me. Had them fail in a car I had decades ago and wrecked it badly. Very good to hear that you avoided that and are safe.
Sooo glad I changed out the entire system on the Ex and my Taurus for Copper/nickle lines. Easy to bend and never ever corrode. Took some investment in time, material and tools, but peace of mind is priceless. Once a car reaches 7 or 8 years old, I like to replace all the lines. They use salt in New jersey. I hate it.
No need to coil it wit the Cupronicle. It has all the flex and spring you will need. I just copied the original lines. Just remove the casings from the old lines and put them on the new ones as you bend them up.
I don't think I will ever use anything else again. It seems too soft to be able to do the job, but it is so easy to bend and NEVER corrodes. Putting a flare on it is easy as sin too. But then again, every flare is easy after I picked up this flare tool from Eastwood when they had it on a killer sale:
Professional Brake Tubing Flaring Tool - Brake Flaring Tool - Brake Tube Flaring
Housedad
That tool is awesome! How much of a discount did they have on it?
I was looking around for a hydraulic flaring tool but it seems they don't go on sale much.
I couldn't justify spending the $300 for the little job I had to do so I picked up a Ridgid flaring tool that I'm so far satisfied with.
MASTER CYLINDER TO HCU
MASTER TO HCU #2
MASTER LINES INSTALLED
DRIVERS SIDE FROM HCU TO WHEEL PART#
ACTUAL DRIVER SIDE LINE
1 OF 3 PASSENGER LINE FROM HCU TO BRAIDED LINE
2 OF 3 PART OF MY SOLUTION TO THE PASSENGER LINE NOT BEING AVAILABLE FROM FORD. (FROM HCU TO PASSENGER WHEEL)
3 OF 3 FROM SMALL BRAIDED LINE TO PASSENGER WHEEL. THESE 3 COMBINED MAKE THE PASSENGER LINE.
I DONT REMEMBER WHAT ONE THIS IS
5 PC BRAIDED HOSE SET
ONE HALF ROLL USED
I used one roll of 3/16 nicopp with about 4 feet left. also i added a union in the rear line making the line from the HCU to the rear axle 3 pieces, it was easier to install this way. i dont think i took any photos of that one. at this point every inch of line or hose has been replaced. only thing left now is to get the rear rotors turned and pads all the way around. but it is back up and running again.
Thanks.
Thanks.
Now I need to see if I can get the union / junction free on the other end of the line. If not, anybody know the part number for that line?
#29
http://www.fedhillusa.com
(and by the way most people are surprised to learn that a lot of brake lines rust out not from salt but from water building up inside the lines. It's cheap preventative maintenance to flush the fluid and bleed the brakes every 2 years or so. Also keeps brake fluid boiling points low which improves braking performance).
#30
It depends on the grade of stainless. I don't consider anything above 400 to be stainless as it does stain and the higher you go it can rust yes. But most any grade below 400 will not rust.
Also yes it can be harder to work with but not impossible. Stainless brakes lines are an aftermarket option. If it were factory they should never have to be touched or replaced so not much worry about flaring them.
Around here in the salt I was replacing steel lines every two years on our trucks, the fluid hadn't had time to collect water it IS the salt that rots them out faster than anything else. Since I have switched all of our trucks to Nicopp we haven't had a line problem yet.
I am shocked to see stainless fuel lines used in many vehicles today but still steel brake lines. They are more worried about a fuel leak than stopping?
