Looking for frame mount running boards or nerf bars
Looking for frame mounted nerf bars and running boards. I found the aluminum boards but can't source a good pair of frame mounted nerf bars with a good size step. Many that I have found are mounted to the sheet metal rockers....seems they would flex and weaken rockers over time especially with heavier weights (280#!)
I saw the n-fab ones but they are also not frame mounted
I know many people who have fabbed brackets to make newer super duty Nerf bars mount to the frame. So if you have the know how, time and newer steps that could be an option.
If not I saw Brad just got steps for his new supercab they look great and sturdy made by a guy for a decent price maybe he could make a crew cab set for you? I do not have the contact info handy but his thread name is supercab steps.
I have attached a pic of where the N-Fab bars attach. They are pricey at about $700 for a set! This price is for the crew cab set that has three steps...cab and one back of rear door for bed access.
They make two types. The one I am thinking of is the N-Fab Durastep which has a larger step. Links below
I like this one due to larger step surface:
http://www.n-fab.com/products/sfID1/.../productID/839
They also make this one:
http://www.n-fab.com/products/sfID1/.../productID/149
I can see the flexing and hitting the bed as a problem for those steps. That being said I just picked up a set this past weekend because #1 I like how they look on the truck and #2 I got them for about 1/4 the price on a craigslist deal.
My plan for them was to mount them with the holes on the rocker panel then have some DOM tubing brackets fabbed up and either them to the frame at one end then weld them to the brackets already on there or come up to the step directly to give more direct support.
Here is set of polished stainless steel. They are made by Go Rhino. They appear to be bolted to frame. They are cab length and do not extend to bed.
How does this install look for strength and no flex?
Link to website pics
4000 Series SideSteps
install instruction
http://www.gorhino.com/images/ePIM/original/4148-i.pdf
install instruction
These are the ones that were on my truck when I bought it:
It's a little hard to read, but they say Westin on the step surface. I can take more pictures if anyone wants more. Better yet, if you want them come take them off my truck. I'll be getting rid of them when I strip the truck for a rebuild since my truck is too low as is to need them.
