F350 20" wheels/clearance lights fit through my garage door opening?
I've looked at specs in the brochure but dimension are based on stock so I'm not sure if the 18" or 20" wheels increase the height. The truck will also have clearance lights other than that the truck will stay stock. The height of the garage door opening is 84" however the rubber gasket that easily moves is 83" so figure 83 1/2 inches. Do you think it would fit.
Truck
F350 6.7 4x4
20" Wheels
Clearance lights
It looks like an f250 would be about 1" shorter based on the specs in the brouchre.
I currently have a f250 18" wheels and it fits fine although I did cut the antenna down several inches so it wouldn't hit the top of the garage opening when parking.
Truck
F350 6.7 4x4
20" Wheels
Clearance lights
I have the same garage opening and an F250 (20" wheels) with the larger F350 blocks in the rear. When I purchased my 2015 truck, my concern was the snowplow prep package. My 2011 and 2015 are the same truck but my 2015 has the larger blocks in the rear and the snowplow prep package.
My clearance lights clear the top rubber strip by about an inch. When we have lots of snow, I clear the drive before I put the truck in the garage.
bruce...
bruce...
bruce...
bruce...
My 2013 Dually FX4 fits easily into my garage door opening, it's that darn metal whip cb antenna that tends to make a lot of noise as it bends over and drags on the under side of the open door.
The fiberglass antennas didn't seem to make all that much noised.......I guessing it had to do with that one single snap noise as they would break off at the base if I forgot to remove them upon entry of the garage.
Coincidental that this thread just came up. I just measured my truck (in my signature below) yesterday while washing it in the driveway. I wanted to put it in the garage so I could clay bar and polish the paint, without direct sunlight. My truck comes on at 81 1/2" to the highest point. Unfortunately though, my garage door is only 79". Glad I measured. I guess I need to put a lift kit on my house and leave the truck stock.
My rental house has the same issue Doug. The garage is long enough, but just not high enough. I had thought of removing the antenna and putting a short rubber antenna on, but those do not get as good of a reception and the radio stations are already static filled where I moved to. I like to listen to live local radio, especially when the weather is bad.
My garage wasn't even long enough for my previous F-150 CC/SB. Height wise, it was fine though. With this truck, I will just have to leave it outside full time. Width is the only dimension that my garage will handle on this truck. Maybe my next house will have a garage that will accommodate better.
DIDit4DAD
2017+ Super Duty
18
12-20-2016 12:44 PM
ryanguy76
1999 to 2016 Super Duty
01-01-2011 04:53 PM
H2oSprayer
32
02-01-2009 08:22 AM
