Extang Encore Tonneau Cover 6'9"bed
Category: Accessories
Price: $450
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: WI
Features
Opens from the front or rear
Cover can be folded up or removed for more bed access
3 panel hard tri-fold design
Heavy duty latches & locks on both front and rear
Ultra tough 1" think panels made of FRP. (Fiberglass reinforced plastic)
FRP looks awesome and provides excellent dent & fade resistance, the strongest frame available
Light weight design makes for easy folding or complete removal
Advanced integrated sealing system
Heavy duty rubber hinges add support and years of use
Unique rails seal cover to rails the ultimate in keep the weather out
Extang is America's number one selling brand
Made in the USA - Ann Arbor, MI
Description:
The Extang Encore tonneau cover is the perfect choice for those who want the simplicity of a tri-fold bed cover with the security of a solid lid. This truck bed cover also gives you the advantage of accessing your truck bed from either the rear or front, something you just can't do with any other hard bed cover.
This tri-fold tonneau is made up of 1" thick fiberglass reinforced plastic panels. Extang has treated these panels to provide thermal stability and protection against UV rays. You also get a textured finish with rubber corners and a powdercoated frame. This means the cover will not only enhance your truck's looks, but it will also be resistant to scratches and dents.
Extang has kept mounting your Encore tonneau cover simple and easy, you won't have to do any drilling or cutting. The independent rails incorporated into the Extang Encore tonneau cover allow for easy removal if you need full bed access.
So if you want a flexible, easy-to-use & secure cover, then you need to get the Encore from Extang. The simple, secure design of the Encore tonneau cover is sure to provide you with years of trouble free use.
randre
09-23-2020 05:53 PM
