It looks good!
If you end up with a lot of oil in the puke tank, Put the loop in the hose up in the air and then back down to the puke tank. Hard to verbalize what I am thinking but if you could just turn that loop up to be vertical rather than horizontal, it will drain more of the oil back into the valve cover.
I've just been getting water and condensation in there. The baffled fittings in the valve cover have helped a lot.
I found a tear in the drive shaft bellow.......and water inside around the drive shaft and bearing. Luckily it only had some surface rust so guessing it was from this past year only. Wiped up and looks and feels like the bearing is still good. Whew!
Depending on how it all comes apart I would look at doing all the bellows as long as you are in there anyway.
Originally Posted by DieselCamper01
Good morning Dave and Cory. Yup, another Monday. yay....
