2003 Navigator won't start after vacation
Sure, and when the available FACTS change, so does everything else.
Gotta have air, fuel and spark for an engine to run. Pretty hard to guess that a critter would make a nest that would block the air. I'd bet your original thinking was that a critter had chewed wiring, not the air filter.
So ran the Navigator today on highway. Seems to be lacking power, and gets a bad shack around 80-85KM. I am guessing some of the debris got sucked in through the throttle body. Is there anything I can do to clean out where it would have got sucked to. I am taking it clogged up on or two plugs. Any advise?
If it was me, I would probably spend 60-70 dollars and buy a bore scope. Maybe from Amazon or Ebay or something. There's some cheap basic bore scopes that are basically cameras on a stick that you can connect to an Android device or similar with Bluetooth and get the image up on the screen there. Then take out the spark plugs and check the cylinders. Try to blow them out with compressed air if you have a compressor and an air gun.
Next step from there would be to remove the intake manifold to clean it and check the intake ports in the heads to make sure there's no debris in there. It's not too difficult if you have some basic mechanical skills and know how to properly torque down the intake so the gasket can seal properly.
The shaking is probably a misfire, which could be related to the broken wire you found on that fuel injector you posted in a different thread.
And you'd be correct as most critters would chew wires long before nesting in the air duct. But either way, it was something that happened while he was away and the truck sat.
Well spent the day cleaning the IAC and the throttle body. Helped alot calm the engine down. I am thinking last thing I should do is seafoam the engine. I know I am suppose to put it in the vacume hose of the brake booster. Anyone have a pic of this location?
Also that little **** was back up my intake last night. Only nibbled the edges, I solved him this time.
Any help with the seafoam would be appreciated.
#29
