Finally getting started on my F1
Sort of. I'll start a build thread once I actually get the truck in the shop and start actually working on it but figured everyone like pics.
bought the F1 a few months ago but didn't want to start it till my other project was finished. But i did start gathering parts like this Mark viii donor and a lexus IFS
Finally got my car finished for the 2nd time
I've had this donor car in my yard for a month or so and 2 days ago decided to get the drivetrain out. This was my first time pulling a motor from the bottom and it was a little sketchy
100k mile Aluminum 4.6 DOHC with 4r70w for $500
Believe it or not my shop was clean before I started on this. Still thinking about using the IRS 8.8 but its something like a 3.08 ratio and thats way too tall with a 4r70w overdrive so by the time i add gears and install i could have just bought a explorer 8.8 and build a 4 link plus I've been wanting to build a watts link instead of the triangulated 4 link that i've built before. Anything you guys can think of that i should snag off the donor before taking it to the scrapper.
Sadly I don't have many, only the ones I took when I first got it home. I should be ashamed of myself for having teased the poor F1. I brought it to a new home with a big shop and got its hopes up that it would be worked on after 20 years of neglect. Then i parked it on the side of the shop and didn't touch it. I know I'm strange
Here's the pics from the ad
Here's when I got it home and $700 bucks poorer
That's a great engine you are yanking from the Mark VIII! I have a '98 donor for a yet undiscovered project that I need to get the drivetrain out of sometime. I'm surprised you didn't pull it from the top.
The F1 looks like an nice project too. Keep up the good work and keep those pictures coming.
Hey Clint,
So what convinced you to pick that engine? Looking at those engine stands
sitting up on top of stacked 2x4 platform - yikes.... I would have let your buddy do the under car bit.
That pic of your beautiful car with the mountains in the back ground could be West Texas - I had no idea Utah
looked like that. Good start on your F1 Project!!! I like the multi paint color look.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Clint,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Why i picked the motor.....
Well I really like the terminator/aluminator 4V motors but the price always scares me off. For all intents and purposes this is the same engine but without forged internals. Second thing is this truck is being built for my wife who's been wanting a truck for a few years now and I'd rather have EFI and overdrive for her than a 3 speed and carb. Third is price, I paid 500 for this car with a bad fuel pump. I got it running so I could here the valve train and all sounded good. So i get 280hp (in its choked up configuration), EFI, 4R70W, power steering, AC, etc.. for cheap
When my nephew was under the car it was on the wheel cribs in the back and on jack stands and a jack as a back up in the front. Now once we got the front high enough to slide the engine out and it was on the jacks stands on top of the cribs i didn't allow either of us to go under it. The wheel cribs are a life saver though if you don't have a lift. I trust them far more than jack stands.
They are glued and screwed and have mitered edges the wheel rest in. You can't get the car to move at all on them
That does sound like a nice alternative to reaching in from the top. I am glad to know this before I tackle mine, thanks!
If I might add, great cribbing.....we were taught that the configuration you have demonstrated will carry 6000 lbs per column (corner) yielding 24k per crib box. Rule was stack not to exceed 3x the base....I've lifted a Cat D6 with air bags on top of a crib box....while they aren't Snap-On fancy...they work!
You asked about parts to save from the scrapper- although not of interest for an F1, there are some components on these that are coveted by those that drive them: the headlight elements (factory HID and not available in aftermarket I am told), the rear neon panel from the trunk with the power supply, and other electronic components unique to this model. How much of the harness are you keeping and are you using a wiring diagram for the Mark VIII to work this in your F-1?
https://www.ford-trucks.com/forums/1...lt-thread.html
__________________________________________________ ________
48 Ford F1 - Darkside
46 Ford Tudor - Lightly Toasted
"Happiness - 3 pedals and a 5 speed"
