Finally getting started on my F1
#32
#36
#37
Lol.... Exactly. I raced Motocross for 20 years so I used to get injured quite a bit. Once I broke my collar bone and tore the ligaments in my AC joint so my collar bone was just floating around in my shoulder. Went to the ER at medical and they sent me home with a sprained shoulder (motrin and rest). Another time i broke my left heel and fractured my right ankle. Same thing they sent me home with an ankle sprain and motrin. But at least both those times I got a call sometime the next week when a real doc took a look at the xrays and they fixed me up
#38
Hopefully you make a speedy recovery
#39
I'm horrible at taking pics and documenting my builds. I get caught up in the project i'm working on and forget. I got the motor mounted but haven't made the trans mount yet so its just sitting on a jack. I need to order a steering column or go to the junk yard and pick one up so I can get the driver side header fabbed up. I got tired of welding so I started doing some metal work to my rear fenders and its amazing how many dents are in these things that the multiple colors of paint hid till i took a 16" sanding block to em. Lots of hammer and dolly work
On the passenger side of the stock mount had this and I figured id keep it so I cut it out with my bandsaw and reused it. This little oblong hole on one side made it so easy to line up the motor when I installed it
#41
Looks good so far. What geometry model did you use for the rear tri 4 bar?
Is that the raised driveshaft notch in the crossmember pic or the original? You must be going to run very low in the back that the DS goes that high? Are you going to have to raise the bed floor to clear the centersection?
I've documented the header fit issues we had with the 4.6 3V we are installing in Gary's F1. I'll be watching how you do it with yours. Those engines are REALLY wide! Maybe the OEM manifolds are a different shape on the Mark? The OEM or aftermarket ones for the 07 Mustang GT even if we would have used an IFS the outlet would have been directly in line with the steering column shaft too close to go around it with the engine centered. Since Ford made the port shape and mounting bolt pattern unique on the 3V heads no one offered any any other header or manifolds that would have cleared. Hence we had to move the engine 1" to the passenger side and have the driver's side header custom made.
If you think it's hard to weld around a circle, build a set of headers!
#42
#43
#45
