2015 F150 3.5l ecoboost Bad fuel mileage
#91
You can always give it back before you register it, don't let them bully you if you change your mind. And if they give you the put 1k miles on it and the milage will come up it won't. They just want you to drive it long enough for you to get stuck in it like I did. But hey there is worse things they getting a badass truck with great power that keeps the oil companies in business. 👍😁
#93
7000 is the gross vehicle weight rating. If you subtract the actual payload of the truck then you'll have the trucks actual weight. Looking at the Ford website, your truck looks to have a 5000 lb curb weight and a 2000 lb payload which makes this a very capable truck.
#94
I was just posting what one of the other guys asked for was a pic of the door sticker. Didn't mean the truck actually weighs 7k just ment the gvrw was 7k. But thanks your right Fords website does have the curb weights but don't think they have one shown for the platinum. Although I didn't look very much maybe they do.
#95
But taking my GVW 7050 and the load limit of 1792 my truck must weigh 5258 which is heavier than I thought it would be.
#96
#97
Something in the back of my mind says there was a 175 lb driver figured into the load limit. In other words, I think your 1792 includes the 175 of the driver. If so, your truck would weigh 5083.
I'll have a look to see if I can figure out where I found that - and if it is true.
#100
#101
#102
When pulling a trailer the weight of the trailer is only a part of the factor for loss of MPG. The wind resistance is an incredible factor in load and will reduce your mileage possibly as much as or more than extra weight. With that, comparing trucks requires some consideration for the aerodynamic shape (Ford vs Chevy, topper versus none, etc.) My 5.0 gets 22 mpg unloaded (4x4 Lariat with 3.31's) with A/C operating. When I drive around town and on short trips my mileage (as stated by someone else earlier) drops significantly to about 16.5 mpg.
I don't see a real advantage to getting the ecoboost on a larger vehicle since a heavy load apparently affects the smaller engines more so that the bigger engines.
#103
#104
Anyway I assume anyone whom spends $57k on truck can afford the fuel. If not then bad decisions were made.
#105
That MPG is not good. What I figure is you have a truck that weighs over 5k lbs, big and wide 20's, very shallow 3.31 gears, poor aerodynamics and a transmission that is going to keep the engine rpm down. Thus the little 3.5l is going to be in the boost. The EB uses the most boost at lower rpms and I believe your engine load is fairly high. Higher engine load, more boost equals more fuel.
