Rear leaf springs on 89 E-150
HELP!
I can't get the shackle to frame bolt off!! All the nuts are off (spring to frame, spring to shackle, and shackle to frame), and the spring to frame bolt is off, but I can't remove the spring to shackle bolt (top rear bolt) because of the way Ford installed it. =(
Any suggestions? The shackle to frame bolt seems to be lodged witth the bushing, and I even used a 230 lb-ft torque wrench - it didn't even budge. But it turned when I used a box ended wrench... it's a 7/8" grade-8 bolt. The nut came off pretty easy, but the bolt is a PITA - the only thing stopping me from finishing the job. So far, the leaf spring is still on, after about 6 hours of labor.
-Charlie
1981 Ford Thunderbird "GT", 5.0L, AOD, 2-bbl (soon to be 347 stroker w/ 400 rwhp)
1989 Ford E-150 Cargo Hauler, 4.9L I6, C6
2000 Ford Crown Victoria PI, 4.6L SOHC V8, 4R70W, 3.55s, Dual Exhaust, Go Rhino Push Guard, Steel rims with Type 170 center caps, Dunlop SP5000 Sport Ultra High Performance All-Season Tires
-Charlie
Any suggestions?
Propane Torch? Sawz-All?
-Charlie
-Charlie
I had the same problem on my 4x4. The bolts were rusted to the steel bushings inside the springs. I used an air die grinder with a cut-off wheel and sliped in between the spring and the mount. Had to cut the end of the bolt off on both sided of the spring. I tried my oxy-acetylene torch first - not a good idea. Ended up cutting the mount on one side. Also to close to the rear fuel tank for comfort.
Funke1
07-28-2015 01:41 AM
busa2009
06-17-2015 12:39 AM
charlie555
04-22-2015 01:45 PM
charlie555
31
03-24-2015 05:25 PM
metroplex
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-06-2010 02:36 PM
