m5odr2
Old 04-27-2015, 05:45 PM
voadrummer's Avatar
voadrummer
voadrummer is offline
m5odr2
Hello everyone, I am dropping a 375hp 4.3 "long rod" v6 in my 2006 f150. Is there any kit to rebuild the m5odr2 to make it stronger or should I just grab a t5?
Old 04-27-2015, 07:58 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
No rebuild kit will strengthen that trans.
What kind of use are you talking?
A T5 might be rated for up to 300 HP in a Mustang, but you are going to be 1000 lbs heavier, so hard use is going to be an issue with a T5.
T56 will solve your problem:
Modern Driveline T5 transmission parts & conversion packages
Old 04-27-2015, 08:13 PM
voadrummer's Avatar
voadrummer
It's going to be my daily driver but will also be driven hard. If I run a T56, what gear ratio should I run being it's a six speed? And thank you for the advice in advance!
Old 04-27-2015, 08:15 PM
85e150's Avatar
85e150
Gear ratio will depend on where this engine makes power and your tire size, amongst other items.
Old 04-27-2015, 09:21 PM
voadrummer's Avatar
voadrummer
Well, if you come across a T56 at a good price, let me know!
Old 04-28-2015, 08:51 AM
1saxman's Avatar
1saxman
1saxman is offline
So the M5ODR2 is the Mazda 5-speed, overdrive high-gear transmission in the V6 manual trucks? I doubt you will need a 'stronger' box. What is the new engine out of, or is it a crate engine? I'd guess I would go with the 3.55 rear or even lower. Your truck probably has the 3.31 which is pretty high.
Old 04-28-2015, 11:05 AM
voadrummer's Avatar
voadrummer
It's a crate engine. I just worry that transmission won't hold up with a more aggressive clutch than the stock one.
Old 04-28-2015, 04:44 PM
85e150's Avatar
85e150
It will hold up to a stronger clutch. It may not hold up to your left foot. If you are going to run this thing fairly conservatively, it will be fine. Racing or otherwise beating on it, you will be transmission shopping, plus other drive line items.
timothy47129
02-08-2017 01:22 PM
Newfiestang50
17
08-29-2016 06:25 PM
blueeyedfordguy
03-01-2010 09:44 PM
79 Trailer Special
02-20-2004 07:46 PM
Katt
Offroad & 4x4
02-23-2000 03:09 PM
Quick Reply: m5odr2
