1996 F250 AC blowing cold...out of defrost only
Old 04-27-2015, 01:24 PM
JoeM1965's Avatar
JoeM1965
JoeM1965 is offline
The air had been blowing cold from the vent...selection seemed to be working well. But, over a 3-week period, it worked intermittently and then stopped working...only getting air out of defrost. I'm guessing it's a vacuum issue...but not sure if it would be under the dash or in the engine bay...any suggestions or schematics?
Old 04-27-2015, 01:41 PM
Holmesuser01's Avatar
Holmesuser01
Holmesuser01 is offline
I'd suspect under the hood first, due to all the heat and vibration.
My own truck had a cracked check valve in the black vacuum line at the reservoir beside the evaporator.
I've seen the white hose at the air recirculate flap motor get chewed off by rodents and cause this, too.
If you do look on the dash, look for vacuum lines that could have gotten caught under your passengers shoes. I've seen these hoses pulled down several times.
Old 04-27-2015, 06:01 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Look for the "Infamous" white vacuum line under the hood, passenger side that runs to the vacuum modulator that controls the blend door function. It becomes brittle and falls apart in sections. I've seen 4 trucks of our vintage with this problem and all 4 had to be repaired.
Old 04-27-2015, 06:32 PM
daddylee100's Avatar
daddylee100
daddylee100 is offline
That's what numerous ones are...^^^^betting that's what it is.
Old 05-05-2015, 02:53 PM
JoeM1965's Avatar
JoeM1965
JoeM1965 is offline
Thanks, all...it was the vacuum line in the engine bay. Took 5 min and less than $10 at the local O'Reilly's to get it fixed. Appreciate all the inputs!
Old 05-05-2015, 05:22 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Glad you found it and replied back with the fix!
Old 09-03-2016, 09:13 PM
94F15012STANG's Avatar
94F15012STANG
94F15012STANG is offline
I have a '94 with no heat control... replaced core, fixed actuator that selects reg air to "max air".. but still no "hot air.. all the venting works correctly ... def, floor, mix.. I just get no hot air... pulling my hair out.. I am doing a mostly restore to this supercab XLT 2WD 5.0.. all interior out and repainted, putting vinyl flooring new headliner.. its all waiting for the silly hot air issue to be fixed.. yes I did a search but there arent any "how to " videos or photos for 92-96
Old 09-03-2016, 10:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,357 Likes on 1,072 Posts
The blend door is controlled by the cable behind the glove box. Is the door moving when you change the temperature setting?
dino360
07-03-2018 09:09 AM
longmire56
1997 - 2003 F150
10-30-2015 10:06 PM
02GrayPowerStroke
1997 - 2003 F150
07-28-2015 07:37 PM
Truckie256
04-07-2013 08:07 AM
MSG
1983 - 2012 Ranger & B-Series
05-12-2003 07:30 PM
Quick Reply: 1996 F250 AC blowing cold...out of defrost only
