Can injectors fill cylinders with fuel while sitting ?
Received 3,102 Likes
on
on
I put some new batteries on it and it will not turn over, should I try and turn the crank with a wrench ? I do not want to drop the starter unless I am sure that must be it but something tells me that is not the problem.
The oil is about 5 inches up on the stick. I already replaced the lift pump too.
on
Well if you replaced the lift pump the fuel must be coming in through either the injectors or the pump correct ?
Something else if you go over one of these engines and do everything right with the fuel system how good are they about keeping air out for like years at a time or is it always a problem with these engines ?
Thanks for replying with the help.
