holley jet sizes
The stock cat no 1850 holleys I run have 66 jets stock on the primary, and that metering plate on the secondary. I have never had a problem with them on the 302's I run them on. I guess I could have leaned them out some, but they never ran "rich" that I ever noticed.
If that is a used carb you should put a kit in it. And while you have it apart, run a file across the main body where the metering plate bolts to the front. You will probably find some warpage and you need to get this out of it. It will run great after that.
on
Just tighten in a chris-cross pattern, snug then an extra half turn, make sure you use your blow gun and clean out all the vent holes that go into the air horn. Alot of people forget about them, and you get a siphon effect, you need gravity to help push fuel thru the jets and idle mixture passages.
fast68
11-12-2007 10:52 PM
351f150texaswindsor
07-22-2004 11:51 PM
