excursion rust repair parts
I am in need of rust repair parts. I need both rear door outer and inner rockers and what would be the rear door cab corners on a crew cab. I'm not sure of the proper name for this. I have searched for this to no avail. Does anyone know where I could purchase these? Thank you. Mark
on
The inner and outer rockers can be bought new from Ford. I replaced my left rear outer. they are discontinued from Ford so I ordered a front outer and cut it to fit. the front is longer so I just shortened it down to the correct length. My inner rockers were good, but the same can be done with those too. The rear lower C-pillar dog leg will need to be either made from scratch or you will have to find a rust free one to weld in.
Here is a thread I did on my rust repair! https://www.ford-trucks.com/forums/1...-rust-ugh.html
Good luck!
Good luck!
crazed87bronco
02-21-2012 06:33 PM
emeraldcoupe
13
09-01-2010 09:26 PM
GQROD
02-17-2010 11:30 AM
