Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Engine/carb match up for a 351W?
Old 04-26-2015, 09:06 PM
85Blondie's Avatar
85Blondie 85Blondie is offline
85Blondie is starting off with a positive reputation.
Recently I bought a 1986 Bronco with a 351 Windsor in it. I was told that the engine in it was not the original one; I just found the block casting number which is D8E6-015E-D
I tried to decode it and I am thinking that it is a 1978 truck engine?
Anyhow, I am in need of a new carburetor, but I am unsure of what type I need. I have a motorcraft that is a 2 barrel, but I am unsure of which I need because there are so many out there.
Anyone well versed in this area??
Old 04-26-2015, 09:30 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud of
A 1978 truck engine would not be a 351W, but a 351M - and that is a completely different engine. So, if you have a W then it is from about 1982 or later, when is when they started coming in.
As for the carb, if you have a 351HO you'll need a Holley 4180 4bbl. But if it isn't the HO then you need an Motorcraft 2150.
__________________
Rusty: '81 F150 Ranger XLT 4x4 w/a 351M, RV cam, Performer carb & intake, C6, & 3.50's
Dad's: '81 F150 Ranger XLT 4x4: Down for restomod: Full-roller "stroked 351M" w/Trick Flow heads, Weiand intake, Street Demon 750/ZF5/3.50 gears w/Kevlar clutches
1950 Chevy 3100 & 1969 Super Bee awaiting restoration
2015 F150 Platinum 4x4 3.5L EB on order
Worst fear: I die and my wife sells my rides for what I've told her I have in them.
Old 04-26-2015, 09:45 PM
85Blondie's Avatar
This may be stupid of me to ask, but I am going to ask it!
How would I find out which engine it is? The previous owner told me it was a 351W, but who knows if that is really what it is. Thanks for clearing that up! I knew the 351w was a completely different engine, but I am not sure how to tell the difference. (I do not know anything about them, but I am learning!!!) Based on the block casting number I am thinking its a 78? If I am correct I do not know.
I looked at the Motorcraft 2150; it looks very similar to mine if not exact!!
Old 04-26-2015, 09:48 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
This is the site I usually send people to for decoding help; the D8 on the Casting Number would be the year the component was *designed* and nothing more. Some parts are used unchanged for decades.
Classic Mustang Part Number Decoding Guide
__________________
About the bra
Microsoft is writing software for the kind of people who'd type google into the google search bar to get to google.
http://news.slashdot.org/comments.pl...7&cid=47003415
Old 04-26-2015, 09:49 PM
Gary Lewis's Avatar
A 335 Series engine, which includes the 351C & M, and the 400, has 8 valve cover bolts and the fuel pump bolts are in a line vertically. A Windsor has 6 valve cover bolts and its fuel pump bolts are in a horizontal line.
__________________
Old 04-26-2015, 10:05 PM
85Blondie's Avatar
Thanks so much for the information!! I went and looked at it and it is a windsor I am unsure of the year now that you mentioned that a 78 truck would not have a 351 W. :/
Old 04-26-2015, 10:06 PM
85Blondie's Avatar
Thank you I looked at a similar site also; the more the better though! The truck is a bit of a Frankenstein and all of this information in the forums definitely helps!
Old 04-26-2015, 10:07 PM
85Blondie's Avatar
So the Motorcraft 2150 goes on the Windsor? It appears similar to the current one? I was confused with what "HO" meant.
Old 04-26-2015, 10:15 PM
Gary Lewis's Avatar
The 351HO was the high output small-block in the 84-86 timeframe. It had a Holley 4bbl carb, DS-II ignition, and no computer. There was also a standard 351W with the 2150 2bbl carb, computer-controlled ignition, and lots of emissions doo-dads. I think that is what you have, judging by the MAP sensor and other stuff in the pics.
__________________
Old 04-26-2015, 10:19 PM
85Blondie's Avatar
Here is a pic! I think the carb is toasted One to many fires.. I just got the truck 3 weeks ago; its going to be a bit of a project, but the price was right. It runs, but needs a new carb (I think), versus a rebuild. Sorry for the huge pictures
Click the image to open in full size.
Old 04-26-2015, 10:25 PM
Gary Lewis's Avatar
That carb doesn't look too bad. And those are easy to rebuild.
__________________
Old 04-26-2015, 10:42 PM
85Blondie's Avatar
Awesome!! Thank you, you are extremely helpful and informative!! I work at a shop as a auto body tech and I have asked a couple of the mechanics about the carb, and a lot of them know nothing about them and could not help me. I have a 1 barrel carter on my 85 Straight 6, and love it. Not a fast truck, but its been a great truck and good on gas.
So I couldn't be lucky and have the 84-86 timeframe
I will have to rebuild the Broncos carb then and see how it goes!
I may have to bug you again sometime in the future for more advice and problem solving!
Old Yesterday, 07:40 AM
Gary Lewis's Avatar
Any time. You can PM me to get my attention, but starting a new thread will get me as well as many people who know a lot more than I do. Good luck.
__________________
Old Yesterday, 10:21 AM
InfantryCPT's Avatar
InfantryCPT InfantryCPT is offline
InfantryCPT is starting off with a positive reputation.
Absolutely the easiest carb to rebuild, what part of the world are you in? The reason I ask is that a Motorcraft 2100 and 2150 are basically the same carb, however the 2150 is for high altitude applications (So don't just limit your search for the 2150). If you don't want to rebuild (It really is the easiest carb to rebuild and there are tons of YouTube step by step videos), I personally have rebuilt 3 of them. Rebuilt Carbs can be had on eBay from $150-300
__________________
$1,400 truck with $2,500 worth of parts, 1983 F250 4x4 XL Single Cab, 460, C6, Edelbrock 1406, Edelbrock Performer Intake, HD D50 TTB, Dana 60 Rear, with AC (almost), lifted with 35" BFG ATs, Borgeson Steering Shaft (the expensive one), Flowmaster 3" Dumps behind the cab, LED Dash Lights
Old Yesterday, 02:07 PM
85Blondie's Avatar
Quote:
Thank you for your message! I live in Florida; I tried calling around for a rebuild kit and the stores want the part number or the year of the truck because they tell me that there are a bunch of different rebuild kits.
I found this rebuild kit, but the gaskets look slightly different:
http://www.carparts.com/details/Stan...2-a01b605e3d08
I checked out some of those videos and I am wanting to try it! I took some of it apart already and checking it out.
If I decided not to I found this, but it looks a little different than the one I have also..
Similar Threads
1977 block into 1996??? misterdave57 1968-2013 Full Size Vans 2 10-08-2014 02:24 PM
need help identifying engine Andyawalsh 1967 - 1972 F-100 & Larger F-Series Trucks 22 03-25-2014 05:47 AM
Need to confirm year 351W Ken Blythen Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 02-11-2009 06:43 AM
NEED HELP WITH ENGINE ID #!!!! for a 51 F100 Mark51 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-12-2009 08:22 PM
transmission swaping DRVNDBUS 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-22-1999 01:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
