Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Can I put the factory tach in?
Old 04-26-2015, 08:38 PM
jason90f150 jason90f150 is offline
jason90f150 is starting off with a positive reputation.
Hey got a 95 f150 xl 4.9 e4od 4x4. I want to put in the tach that xlts had in them in my dash. Will it just plug in and work? Or do I need another harness plug or something? My rear tank reads way past full too but Im working on that too. I think its an open sender wire.
Old 04-26-2015, 10:20 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You can swap in a factory tach but you will need a complete cluster from a '94 or '95 truck with an I6 and you will want to transplant your speedo into the new cluster to retain the trucks milage. The individual gauges plug into the cluster from the front but all those gauges except the speedo are unique to the tach cluster so you can't just add a tach to your cluster... in case you were wondering.
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 04-26-2015, 10:29 PM
Sweet thanks. Guess I'll be going to have some fun in the junkyard! I figured I had to replace the entire cluster but I wasn't sure. I'd much rather have the stock tach in the dash instead of an aftermarket one mounted somewhere.
Old 04-27-2015, 12:34 AM
ponykilr's Avatar
ponykilr ponykilr is offline
ponykilr has a good reputation on FTE.ponykilr has a good reputation on FTE.
Installing An OEM Tachometer In A 1992-1996 F-150 Or Bronco - Ford-Trucks.com
Should be a sticky
__________________
My build Thread
Old 04-27-2015, 06:14 AM
LSCRX LSCRX is offline
LSCRX is starting off with a positive reputation.
Quote:
The '95 has a digital odometer, wouldn't the mileage be stored on the ECU?
Old 04-27-2015, 10:28 AM
katjtodd katjtodd is offline
katjtodd is starting off with a positive reputation.
Quote:
No. The mileage is stored in the speedometer module.
Old 04-27-2015, 05:20 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Any 94 to 95 F-series(except diesel) tach cluster will work in your truck. The wiring harness lets the factory tach know if you have a V8 or I6.
Like Conanski said :"... swap your speedo onto tach cluster ..." to keep your milage and ratios the same.
__________________
95 E350 460/E4od 4.10 The Bus
89 F250 2x4 300/AOD 3.55
84 F250 4x4 300/np435 3.55 The BLUE MULE
85 Plymouth Caravelle
73 Buick LeSabre
Similar Threads
installing a tach f-150 XL FourPointTwo97 1997 - 2003 F150 4 11-12-2007 10:04 PM
Diesel with gas tach? IDfordguy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-26-2005 01:00 PM
Aftermarket tach. mustanguru 1987 - 1996 F150 & Larger F-Series Trucks 3 07-09-2003 04:43 PM
tach and gauges snifferdog Aftermarket Products 3 07-21-2001 09:47 AM
Tachometer purchase questions. TallPaul Aftermarket Products 6 06-26-2001 02:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
