What would McGuyver do?
I just did the kingpins on my one ton panel truck without any of the special tools usually associated with the job. There is no machine shop on the island so like with a lot of my repairs I had to get creative. This was on a '47, but the same as most of your trucks. To remove the old pins I welded a 1/2" bolt on top of the stuck kingpin and placed a socket for a spacer over this bolt. They wouldn't budge so I applied heat and the usual pb blaster and had a beer while it cooled. Then another quick heat and put tension on the bolt. Pounding from underneath with a 3 lb hammer onto a 5/8 short bolt held with vice grips, I was able to get a bit of rotation on my socket wench. I went back and forth between the hammer and the wrench, each couple of beatings yielding about 1/4 tun on the wench. Finally my employee stopped by to get some tools and he held tension on the socket wrench while I pounded. This resulted in a fairly steady draw and produced quick results. Next I pressed the old bushings from the spindle with a socket and my vice and pressed in the new ones with the same method. Now to ream the pins to fit the new bushings I took a 3/4" hardwood dowel and slotted it down the center with my bandsaw and tore 2 strips about 3/4" wide from a 120 grit sanding belt. I folded these into a long 'L' shape and put them in the saw kerf on the dowel and secured with a split piece of poly pipe and a hose clamp. Turning this with my cordless drill, I was able to hone the bushings in a very controlled manner, with really nice alignment. The results were excellent and when completed and oiled they would slowly slide into the bushings under their own weight. They are now back on the truck with a tie rod I borrowed from my 1/2 ton which I plan to restore in the future. Hope this helps somebody. It was actually kinda fun.
Looks like I said I reamed the pins to fit the bushings. Obviously it was the other way around. Reminds me of that old bumper sticker 'dyslectics untie!' While I'm showing off my hillside machine works, this is how I surface heads and manifolds. I love the look on peoples faces when I say I surfaced my cylinder head on my table saw.....
Hey GB,
Looking good over there!!! Ingenious! Have you seen a recent pic. of McGyver lately? Hmmmm......
Is That You, 'MacGyver'? See What Richard Dean Anderson Looks Like Now | ExtraTV.com
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey GB,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey GB
I always liked Officer Bill Gannon - always wondered what he had in that lunchbox of his.... Ginger was a realtor in L.A.
still looking pretty good - but it's been a few years...... I hope I pass the age test..
I like keeping track of your truck fleet - What's your latest update? That Powerwagon was sure cool...
Ben in Austin
1950 F1
Ben in Austin
1950 F1
This tonner panel has been a huge draw on my time since I got it in February. I can't leave it it alone but it needs EVERYTHING. It was used really, really hard. I'm thinking maybe in a mining operation. Dynamite wagon??? 3 of the leaf springs have multiple breaks, Engine stuck bad, steering was locked up until yesterday, all tie rod ends falling apart, running boards almost disentegrated, seats (rare original pair) are just springs. The rear axle assembly was in 2 rough pieces and unusable, clutch was in pieces in the bell housing. Hood caved in, no doors shut right. Well maybe the pass door, but it's locked shut. All other latches are non functioning. One piece at a time It's coming together. The trip to Tinman's place was very beneficial in parts (and time away from work, work, work) Tomorrow my 2' length of 3/4" teflon rod should arrive and then I can make the buttons that will replace the circlips im my 59 ab's pistons. I will get some pics of that operation tomorrow. Oh and yes, Gannon. Yes, you pass the test.
Matter of fact I posted that same pic on the fordbarn today. I have been dabbling a bit on there as I'm rebuilding a 59ab, mostly on my kitchen table and they have a couple of guys who have devoted their lives to rebuilding the flathead v8. I referenced the thread to me living on an island so titled it 'How would Gilligan and the Skipper do king pins?' It pretty much got all bogged down in Gilligan's Island banter so I lamented I shoud have used 'McGuyver instead. It is pretty funny though. Especially one guys post of how Gilligan looks today. Of course it includes the age old Ginger vs MaryAnne debate......I thought it was rare to see so much sillyness on fb, as I normally think of them more like Detective Joe Friday. That's an age test btw.
