Motorcraft fuel additive
Thanks for the replies, my truck is only a month old now got it used. I was running diesel clean which I didn't notice any difference from not running anything. But just nervous if I needed any repairs ford would see I was running something other than Motorcraft products. Does any of this stuff actually work anyways? Or is it just a gimmick. Im basically running it to help protect the injectors and pumps.
Its a cetane booster and a lubricant product as well. I do not know the actual manufacture of the ford product but personally i didn't see much of an improvement in comparison to the The Opti-lube. Check it out and do your own research but i don't think you will find anything better, at-least i haven't yet anyways.
Opti-Lube XPD Diesel Fuel Improver | The Best Diesel Fuel Additive
You will not see mileage gains or dramatic changes in performance using fuel additives however, when our great government took the sulfur out of diesel fuel they eliminated the main lubricant for our fuel systems. Some of the additives provide an alternate fuel lubricant and fuel system cleaners in addition to improving the cetane rating.
If you want to try something different take a look at this. The product is awesome i have zero complaints and have using it religiously the last 2.5-3 years. It out performs the Stanadyne products i have previously used which in my opinion was the best on the market tell the Opti-lube products came out.
Thanks for this info. I will give this stuff a try.
For the PM22A, I add 4 oz at 1/4 or lower, which is still extra for the small tank but makes it easy. If I fill up at 1/2 the next time, I don't add any. If I fill up at 1/2 again, maybe I'll add 2 oz but depends how I feel. Most of the time I'm refueling at 1/4 tank. The 4 oz treats 26 gallons. Yesterday I was in southern AL and noticed the Shell station had a minimum 40 cetane sticker so I didn't hesitate to add 4 oz. Shell is typically 46 so that's probably what it was anyways.
