Newbie to Change 7.3l Turbo, Tips?
A Neighbor wants me to pull and rebuild her turbo from a 95 f250. I have a good amount of wrenching in the past mainly on 4 cylinders (4g63) and have rebuilt many turbos for those cars and a few diesel turbos, so I'm not going in to this completely blind but I have never worked on these trucks before.
My main question is is it common to run in to bolts that will require extensive heat or other non traditional tools to remove it? Or worse break off? I have read some of them are hard to get to and you need a lot a patience but I want to make sure I can do this job with semi basic hand tools and not get in to a situation where the turbo is half off and the woman is with out a working truck.
Thanks in advance for the help!
You don't indicate which part of the country you are in, but if you are in or close to the rust belt and the turbo has never been off, you are in for a very long day.
Make sure to have multiples of every tool listed above as we often break all of them several times during a turbo removal.
If you are fortunate enough to live in the South or the West, then it might not too bad of a job.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I would also start spraying the crap out of all of the bolts with a good penetrating oil... You will be happy you did no matter what. You will absolutely need a set of swivel socket to get to the bottom two collector bolts and 1/4 swivel an 10mm with a 3" extension to get to the two rear pedestal bolts.
I will also note the housing bolts on the turbo itself are 8mm 12 point heads. Make sure you have one of those sitting around if you plan on rebuilding it.
Its really not that bad of a job, your chest gets bruised for laying on top of the block for a long time with very limited space against the firewall to wrench... I hope she is making this up to you!
96_7.3_Dually
13
06-29-2011 05:44 AM
thegreatwhitefarmer
12-16-2009 05:45 PM
