1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Timing chain Navigator
Old 04-26-2015, 03:29 AM
300zx's Avatar
300zx
300zx is offline
I need help to put the timing chain on my Navigator. I have 01 Navigator with DOHC.
Head has sent to a machine shop to check valve and replace the chain and tensioner. We put the head and torque it to specs. Set the timing (passenger side)right hand to 11 o'clock, (driver side) left cam to 12 o'clock and the crank at 6pm. Put the single marking of the chain at the crank and dual marking of the chain at the cam. Release the pin. Put the other chain, release the pin and i double check the marking. 11,12 and 6. in some reason when we rotate the the engine (by hand) it will go for about 240 degrees and stop and wont go anymore. We check the engine with the camera and all the piston is not heating any valve. Need help. Any ideas?? Thanks
Old 04-26-2015, 10:18 AM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
You say you have a DOHC but your description sounds like you have a SOHC. If you do have a DOHC setup then follow the procedure in the attached PDF.
File Type: pdf
Old 04-26-2015, 04:58 PM
300zx's Avatar
300zx
300zx is offline
Thanks. when i send my head at the machine shop he said everything is set just need to set my timing on cam and crank. Did i set the timing right? 11 o'clock passenger(right), 12 o'clock driver side(left) and crank at 6pm?
Old 04-26-2015, 05:20 PM
FoxFord33's Avatar
FoxFord33
FoxFord33 is offline
It really depends on how the copper colored links line up with the timing dots on the sprockets. That's how to time it properly. You can be a few links off from where the timing dots are, but the only way to know is by finding those two "king links" in each chain. You may have to polish them with a rag in order to see the difference in color on the links.
Old 04-26-2015, 06:39 PM
alloro's Avatar
alloro
First I need you to confirm how many cams are on each head...1 or 2?
Old 04-27-2015, 08:37 AM
300zx's Avatar
300zx
300zx is offline
its a DOCH. dual over head cam. What puzzle me was its hitting on something but when i use the camera to see where its hitting, cant find anything that its blocking the piston or the valve.
Old 04-27-2015, 10:17 AM
alloro's Avatar
alloro
Did you perhaps drop a small socket or bolt inside one of the cylinders before bolting the head down?
Old 04-27-2015, 10:44 AM
alloro's Avatar
alloro
I found this picture of the DOHC timing chain setup if it helps.
Old 04-27-2015, 01:38 PM
pdqford's Avatar
pdqford
pdqford is offline
Good thing you turned it over by hand, first!
Wait! I think maybe you have it correct.
But the big thing is to count the side links.
The single colored link would be over the timing mark at 6 o'clock at the crank.
And the double colored link would be either side of the timing mark on the cams.
Did you verify the 30 side links per alloro's picture?
Also, double check that the secondary chain is timed correctly.
Old 04-27-2015, 04:38 PM
300zx's Avatar
300zx
300zx is offline
The chain is new so i can see the the difference. There's one black and two black at the other end if i fold it it match the length. I have a camera put in to check the piston and valve but there's none hitting. That's why i'm confused. I'll check the pdf that alero send me. Hoping that the guy from the machine shop put the timing wrong.
Ill send some pictures tomorrow. thanks
Old 05-15-2015, 11:42 AM
300zx's Avatar
300zx
300zx is offline
I need help. I need to know where is the 2 pin connector (close to firewall and driverside head) connected? I check all sensor but cant find close to it.
Old 05-15-2015, 12:25 PM
Skauber's Avatar
Skauber
Skauber is offline
Might be knock sensor? You didn't say if it's on the inside of the heads or on the outside between engine and brake booster.
Old 05-15-2015, 06:12 PM
pdqford's Avatar
pdqford
pdqford is offline
Could be the EVAP Canister Purge Valve or the EGR Vacuum Regulator Solenoid.
Can you determine the wire colors? That should help narrow it down.
Old 05-15-2015, 11:40 PM
300zx's Avatar
300zx
300zx is offline
Its behind firewall and head (passenger side) Here are some of the pictures. Any help will greatly appreciated. Thanks
fuel rail passenger side. thats the connector look like.
the color of the wire looks like brown with green and brown with red.
Old 05-16-2015, 01:10 AM
Skauber's Avatar
Skauber
Skauber is offline
Not sure how similar the harness and sensor configuration is between the DOHC and the 3V engine, but on my '05 3V the only connectors back there are knock sensors (X2, one on each side, 2-pin), the IMRC connector (4-pin) and CHT/Cylinder head temp sensor (2-pin, it also has an extender connected between the harness and the sensor itself). If it's more towards the outside, then we're starting to talk about coils and injectors, if you're sure all the injectors and coils are correctly connected, then we can rule those out of course.
Quick Reply: Timing chain Navigator
