Kingpins - Metal or Nylon bushings??
Hey guys, I have to replace my front Kingpins on my Suspension, and I was wondering, should I get a Kingpin set with Nylon bushings or Metal ones? I found LMC sell sets with either one and Mac's Antique Auto Parts sell a set with only the Nylon bushings.. Any advice guys?
When I did mine a few years ago I talked to my front end alignment shop first (he's an old timer and expert on this sort of thing) and he said he would absolutely NOT have anything to do with aligning my truck and guaranteeing it if I were to use nylon bushings. So I bought metal. And he was happy. Check with your alignment expert and see what he says.
Bronze bushings, precisely reamed for proper installation will last the life of the truck, if properly lubricated.
I put new king pins on with bronze bushings in the early '80s. When I upgraded to disc brakes about 2010, the bushings were tight and clean. Changing the king pins for the disc brakes took just a few minutes because they just slipped right out.
Nylon ones quickly wear and put the tires out of alignment.
I consider the slightly greater expense of the bronze installation to be worth more than easy installation of the nylon ones.
Noticed some play on kingpins while stripping drum brake setup off of my 66 F100. Purchased NAPA replacement kingpin kit with metal bushings. Promptly split open one bushing while trying to press into spindle. While considering that, I found that the kingpin is a larger OD than the bushing ID. I'm guessing the metal bushing replacement into the spindles is a job for a machinist?
You can do it yourself if you have the reamer and the skills. I had neither, so to the shop they went.
