New Carb 58 F600
New Carb 58 F600
Hey all,
So last summer when I went to start up the old beast I noticed the carb was leaking. I tried to rebuild it and failed miserably apparently because it wouldn't even idle when I put it back together.
Fast forward to today when I installed a brand new Holley 2300 500CFM carb. I hooked it up and that old truck just purred. She sounds like a brand new vehicle.
I was wondering if anyone had any advice on how to run the fuel line? Here is a picture of the temp setup which has the fuel line laying on the exhaust
Run it like that for a while and your troubles will be over.
I wouldn't even start it with the line running like that.
How was the stock line run?
You want a metal line as far as you can run it, and if you need a flex, use some braided steel type line, preferably with real AN fittings.
Rubber fuel line always deteriorates and is always vulnerable to damage.
http://www.summitracing.com/parts/su...FcqVfgodZ7QAVQ
Fittings for Holley Carburetors
04-23-2014 09:31 PM
Vegas123
33
08-07-2013 11:10 PM
littlefoot
17
12-27-2003 03:49 PM
archangel
08-25-2003 12:48 AM
