what power adders have used on your gas truck and with what results
There does not seem to be much discussion on power adders so I will try to start something. I haven't done a blower on this f150 I built yet. I will need to put a set of forged .040 over pistons in it and if I do that I had might as well stroke it at the same time and add a set of heads cam ... got me thinking about what other people have done to there gas trucks
on
My end goal is a vortech s trim with 349 cu in stroker with these tfs tw 170 heads similar to what I am building the wife for her stang. I think 440 hp at the 6000 rpm mark is doable. With t he added cubes and overdrive the blower to move boost earlier should make good tq. Numbers
But started this thread to get an idea or chronology of setups that work and some that dont for all to read.
Keep the boost down to under 8 lbs or so and you won't need those forged pistons.
Most factory supercharged vehicles didn't use 'em. Even the aftermarket outfits that sell Roots-style blowers like BDS, Supercharger Shop, Dyers, and others say the same thing.
I DID use forged pistons in my last hot rod build, a blown early Hemi, but it was more of a matter of piston availability than anything else. By the time I got a cast piston built to my specs the forged ones (Venolia) were only a few bucks more.
Since then, I've put on a better set of heads, roller cam, 62lb injectors and a pulley change. It should make at least 500hp/600tq, or better, at the wheels.
