Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Help Needed
Old 04-25-2015, 06:50 PM
Bluet1k Bluet1k is offline
Bluet1k is starting off with a positive reputation.
Help Needed
I had my transmission overhaulded (aode). I found that when I start slowing down at a red light and get down to around 20mph and the light turns green again so step back on the gas it feels like the transmission slips really hard before it catches. Then the OD light starts flashing. I tried the code test but can not get it to work. Tried a wire and a paper clip but can not get the truck to show any codes. I would really appreciate any help. Someone said it was probably the torque converter so i bought anther on (had a new one already installed when the changed the trans) and that did not fix the problem.
Old 04-25-2015, 07:04 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Share some more info on your truck.
Getting codes is key to solving this issue so that problem will have to be fixed first. Does the check engine light turn on when the key is first turned on? Make sure the bulb isn't burned out. What procedure did you follow for the DIY code test?
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 04-25-2015, 09:08 PM
Yes the light comes on when i turn the key on but then goes off. I put a jumper in the ground plug and the top right pin. I hooked up exactly as all the diagrams i have found online and in the sheltons manual. Then i turn key on. the check engine light comes on after a few seconds goes off and never blinks or anything. Tried it with the truck running also.
Similar Threads
1999 Ford Ranger Overdrive Transmission problem Geomin Ranger & B-Series 39 05-07-2015 06:12 AM
1998 Ford F150 P0782 2nd - 3rd code jameskgo 1997 - 2003 F150 0 03-27-2015 04:41 PM
Turbo issues Deislife 6.0L Power Stroke Diesel 1 03-03-2015 07:54 PM
HELP ME SAVE SOME MONEY AT DEALER! HAVE WRENCH LIGHT AND SOME CODES ryanbodden2014 6.4L Power Stroke Diesel 1 12-26-2014 02:19 PM
97 F250 shifting issue - only code pulling is shifting sensor whisper237 1994.5 - 1997 7.3L Power Stroke Diesel 19 10-06-2014 04:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
