Taller valve cover
Taller valve cover
Hi folks,
I have a quick question. I recently installed a reman engine in my 81 f-150. The head on the new engine is a bit different than my core was, and has a taller valve train...which is causing clearance issues where the PCV baffle on the valve cover is. It's already been hammered down to where the PCV is barely staying in, so I'd like to try to find a taller valve cover.
I know I can just go get a Clifford aluminum one, but they sure are proud of that sucker! I'll call that a last resort.
Does anyone know what year 4.9/300 had the tallest valve cover? I can watch the jy's for one and get it. The last trip netted me nothing, they were all short.
Usually the problem is solved by cutting two valve covers (like a hot dog bun) and welding them back together in one taller one.
Another possibility is to locate a VERY RARE 3 x 6 prototype tall valve cover - never made it to production. I'll post pics.
Anglia has stock mid '60s thru mid-'80s valve cover.
White RPU has RARE 3 x 6 valve cover.
Blue unrestored altered has cut-and-spliced valve cover.
I think that EFI valve cover would work, now that I rethink the issue. It wasn't that the valve cover itself was touching, it was the baffle for the PCV. The EFI looks like it's taller in both the filler and PCV locations.
To the junkyard I go!
Thanks Zark, I'll update the differences for posterity when I get done with that measurement.
As far as height, i don't believe there is any difference. the internal baffle of the cover is located different on the later model valve covers though. it had to be reconfigured for the pedestal mount rockers as they take up a little more real estate under there. what kind of rocker arms are in the cylinder head? reman'd engines could have either or type of cylinder head that facilitates different rockers on them. you could make the other work by just trimming some of the sheet metal down from the baffle itself. it'd save you a few bucks and a trip to the j/y.
on
Well Zark, that was a great idea. I went to the JY, got a nice EFI manifold, cleaned it all up, and then took some measurements to compare the old with the new(er).
The "Powered by Ford" 1981 VC has 2 3/8" clearance to the shortest internal spot between cylinders 5 - 6.
The EFI valve cover has 2 5/8"+.
and the finished job.
Thanks =)
I had a weird squealing noise show up after installing this...very weird noise! Lemme tell ya, I thought something got in the engine and was wreaking havoc. I opened the oil filler to see if I could narrow it down, and it sounded like a huge gasp for air and the noise was gone.
Turns out that because the engine is so new and has zero blow-by and apparently great ring seal, the PCV was doing a really good job creating a vacuum. The old VC had a breather style oil filler cap. This one does not.
Now I need to find a decent breather to go into the vent hole behind the filler neck in the new VC.
Whew, time for a beer.
53OlderThanMe
09-08-2008 10:00 PM
