Lift recommendations for a 2013 DRW
Larger wheels with smaller diameter tires like you often see don't cut it - I had 35" Buckshot Mudders on 15" rims (standard back in the day), no lift and drove pretty much wherever I wanted.
Ideally the purpose of a lift is simply to accommodate the taller tires, though I see plenty of lifted trucks with small tires .
Most tires get wider as they get taller. The Buckshots I ran had a different aspect ratio, P or Q I think, which allowed them to be taller but not wider. They cleared better than the 33x12.50 tires I originally had.
Try to find a shop specializing in truck tires to find the tallest ones you can put on a dually.
I plan on getting 275-65-20's for my dually when the time comes, of course this will mean new wheels but I know they will fit without a lift because that size tire is a factory option. I don't want to go the wider tire on factory wheels route because I am afraid of the duals rubbing, a bead popping with a heavy load like a 5ver, tire squirm, uneven tire wear or accelerated tire wear and some tire shops won't do it. My .02
There are tires that are taller and almost stock width, I'm running 255 85r16 tires on my F350. 33" tall and 10.8" wide I believe, they have the same in 17" and 18" wheels you just have to look, if not there are companies that sell wideners for duallies so the tears don't rub. But I'm still up for a nice 2-3" lift with one size up on tires, I see this a lot on Ford dually's and if I ever went with a dually id do that and leave it
iPhone from IB AutoGroup
Nowadays it's auto manufactures listen to the majority of truck owners that use their trucks as soccer mom vehicles. Soften up the springs so it rides like a car but then you have to spend money to add airbags etc cuz YOU use your truck as a truck! 4wd is added just so u can back out of your driveway to drop the kids off at school, so there is no need to have the truck jacked up high from the factory, but again those of use who use our trucks get damage like your getting not from off-roading or rock crawling but just normal driving on u paved roads like a field or logging road! Then again your back to adding a lift and bigger tired to make your 60k truck a actual truck
It would be nice if Ford had options like that. An offroad package that really means something, maybe for duallies a 2 or 3 inch lift with one or two sizes up tire option, a winch, air bags, traction bars. I think they would sell a lot of these trucks but for now we have to do it ourselves.
A1C DiMaggio
19
06-10-2013 02:09 PM
