85E, thanks for your advice. I may just run it for now and look to pull it in the future (the oil pressure doesent seam to be as much of a concern as I thought). I just put an actual pressure gauge in over the weekend and when I saw what the PSI was when the engine was warm, I got concerned. TWIGS, I hope Im not where close to that much bearing ware. I have close to 0 oil loss every 3000 miles.
With my old 2.9 I only had 9/10psi oil psi at 1000rpm hot, with 15-40w and with a half a QT ofLucas oil stabilizer, The previous owner was horrible with maintenance and repairs it's literally been 98% of the needed repairs to the truck to keep it running since I've got it.... Still the best 500$'s I've spent on a truck.... And 500$'s on a BII that had driveshaft and severe rust issues with low miles with a lot of money spent on it before they figured out it was a lost cause... The BII's motor still had honing marks on the cylinder walls... 3000 miles in my Ranger and no oil loss and the oil still looks like you dumped it in and started the engine and checked it. I bought the BII only for the rear axle years ago and is been sitting in the Weedpatch until I decided to put the engine in my Ranger.
If your using a Delo or Rottela 15w40 you shouldn't need the oil additive. Also get rid of that Fram filter, they are garbage. run Wix, Purolator or a motorcraft filter.
I am running Rottela so I'll give it a shot with out the additive next oil change and see how it does. I've also read alot of negative things about the fram filters lately so I'll renew that with something else also.
Thanks for all the replies. Im looking into renewing the bearings to correct low oil pressure when the engine is up to temp. No knocks or unusual noises, truck runs great, just looking to bring the pressure up a bit. Right now Im running 15-40 with a can of Lucas Oil Additive. At cold start up the pressure it at 40psi, when warm its at about 14psi at idle. Idle RPMs are at about 1000. I wanted to renew the bearings the easiest way possible, but it sounds like there is not short-cuts to do this. thanks again for the replies
I would suggest running straight 30W, my 1990 302 with 169,000 runs very well with it. It has reduced oil consumption, which was my main reason for using it. I don't have exact readings on the oil pressure but the stock gauge reads higher at operating temperature than when using a lower viscosity oil.
Part of the reason for an oil pressure drop is due to the expansion of the metal parts which increases the clearances, thus the oil has an easier time flowing out into the crankcase. Higher viscosity, even at operating temperatures, reduces the flow out into the crankcase.
