missing fuse
Received 3,090 Likes
on
on
only if the trailer plug gets moisture in it and shorts out. then it will blow the fuses, and when you go to use trailer brakes or battery charge circuit they will not work, causing you a lot of head scratching. if you do not tow much, you put the fuses in when needed, then take them back out when done.
when i first got my truck, every time i went to use the trailer hitch i had to replace the fuses. so i now just leave them in the center console and only put them in when needed.
Surf4321
03-02-2018 01:30 PM
nova801428
12-05-2017 08:20 PM
rcvic
12-21-2011 09:28 AM
