Wiring Aftermarket Fuel Gauge...???
Old 04-24-2015, 07:26 PM
deyomatic's Avatar
deyomatic
deyomatic is offline
I bought a Stewart Warner fuel gauge to replace the stocker in my '60 F100. On the back side of the stock one, there is a red wire that goes to the tank sender and another connector with two wires coming out of it which is switched 12v. I assume that one wire brings the power in, and the other goes out to other gauges.
I am also assuming I can just snip both of the 12v wires and put connectors on them and attach them to the new gauge and the system won't know the difference. Am I correct, or should I try to find another switched 12v circuit...if so, what would you recommend?
Thanks.
Old 04-25-2015, 05:57 PM
spurredon's Avatar
spurredon
spurredon is offline
What does Stewart Warner say?
Old 04-25-2015, 07:09 PM
deyomatic's Avatar
deyomatic
Stewart Warner's customer service is a joke. I wasn't worried about the gauge, I was worried about what that wire was connected to in the truck. I did it, then I think I fried the voltage regulator, then I tied into the other wire going into the voltage regulator and it's fine.
The short story is that it's for factory gauges, and all of mine are now aftermarket, so it's good.
df85732
10-03-2016 05:20 PM
vwfreak
06-09-2012 09:43 PM
Baxdoc
Electrical Systems/Wiring
04-03-2011 04:34 PM
mosgo1
11-19-2008 08:02 PM
red and white truck
04-11-2005 07:23 PM
Quick Reply: Wiring Aftermarket Fuel Gauge...???
