Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
different cab wiring help
Old Yesterday, 06:58 PM
dentsidejay dentsidejay is offline
dentsidejay is starting off with a positive reputation.
I have a truck i just got with a 1974? f150 frame and 300 inline 6 manual 4 speed with granny gear (PO said non-ac)
It now has a 1978 f350 v8 auto cab with a/c.
The wiring is a little mixed between the 2 and i'm not sure if i can decifer colors/tracers anymore.
It needs a new battery and some fused link wiring
I know it needs an ignition module.
I have a few rebuilt 3g alternators i'm looking to put one on.
Is there anything not compatible? If i follow one wiring diagram or the other will i fry something?
I know i'm an arm chair mechanic right now, but i want some do's and don'ts before i ruin the truck. thanks in advance
Old Yesterday, 07:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to behold
The '74 and '78 modules don't interchange. '74 was a one year only version.
It's easy to tell which you have. Look at the plastic grommet that surrounds the wiring where it enters the ignition module, if its blue, you have the module for the '78.
That's how the modules are identified, by the color of the grommet. The blue is the best and most common.
I can't remember off hand but I think the '74 grommet is black.
Old Yesterday, 08:54 PM
I'll check on that tomorrow, thanks.
Old Yesterday, 09:05 PM
Brian Ski 44 Brian Ski 44 is offline
Brian Ski 44 is starting off with a positive reputation.
Why is the blue one the best??? I have an off road vehicle that has no top end. It is running really bad right now. I am not sure if it is fuel or ignition related. It is running the blue module. Was thinking of replacing it or tearing down the carb. Which should probably be done anyway. Last year it was getting rough and now it is really bad.
Old Yesterday, 09:31 PM
mikeo0o0o0's Avatar
Quote:
By the time Ford started using the blue grommet version they had pretty much gotten most of the bugs worked out. The '74 and '75 each use their own module and neither interchanges with any other module. The blue version came out in '76 and was use, as I recall, into the mid nineties on certain applications.
If you do replace it, spring for the extra money and get either genuine Ford or genuine Motorcraft. The cheaper imports have a very high failure rate.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
