New Tires
Those Long Trails should provide the low noise and soft ride along with a very good tread life.
Noise and ride were not too high on my priority list as i went with one of the more aggressive AT tires around in a load range E. My truck is mostly driven in snow, with a trailer behind it or into the woods on hunting trips. My economy car sees almost all of my time on the highway.
You definitely got a good tire for your needs. The BFGs are very good. I'm finding the right pressure for them to get a balance between efficiency, long life and ride quality. For now, 35 psi cold - very cold - I set them yesterday morning at 45 degrees, which is probably the coldest it will be here until Fall. That gives about 37-38 psi on the highway which seems to be a good balance. I had my nose rubbed in the tire pressure thing so now I'm a little obsessive on it. Back in the late '90s I had a Jeep Cherokee. Unknown to me, my oil-change joint was over-filling the tires. I was not checking behind them. I had BFG Radial T/As on it which should have been about 32 max, cold. I drove the Jeep on several long trips during that period, some of them down South in blistering August heat - it's a tribute to the BFGs that I didn't have any blowouts, because I later discovered they had been pumping them up to 50 psi. But what did happen was the tires had belt separations, resulting in wheel shimmy, uneven brake rotor wear and the dreaded 4X4 'death wobble'. I never was able to solve it until I realized the tire pressure problem (which went on for about two years) and finally put new tires on it - it instantly rode like a magic carpet. From then on, I check the tires after ANYBODY touches the car for any reason. If the place has air, they will screw with the tires. And another thing - nobody could find out what was wrong with it at the best tire/front-end/frame shops in the area. Nobody ever checked tire pressure or checked for 'bumps' in the tread indicating belt separations. To this day, the whole question of tire damage from over-inflation and the resulting effects on ride quality remains little-known, which is why I bore everyone with my tale every chance I get. And why I check tires on our three vehicles every damn week. Since that episode, I have never had anything but soft, quiet-riding vehicles with no balance problems and no brake chatter.
MikeMcCasland
1999 to 2016 Super Duty
10-01-2009 05:46 PM
pops_91710
12-16-2006 05:04 PM
