460 Rear Main Seal
460 Rear Main Seal
I'm having some oil leak from the rear main seal of my '95 460ci with the heavy duty auto tranny. With the good possibility of having to replace the seal, do I need to remove the tranny or just move it back?
This would be a new project for me since my mechanicing experience is limited.
Thanks for the help!
Probably easier to remove the engine. If I recall properly, you need to jack up the engine 3" or so, remove the oil pan, remove the rear main bearing cap, loosen the other main caps 1/64" or something like that, and then you can get enough clearance to properly do the seal.
This is from the Ford Repair Manual I think.
Just did my 96 F250 4X4. I pulled the engine but I also had a couple freeze plugs leaking plus I needed to resurface my exhaust manifolds and replace the bolts, gaskets and studs.
It was easy with the engine on a stand. Pull the pan, take the rear main cap off. Then a few good taps with a hammer and a small punch on the steel ring in the seal will drive it out far enough to grab it with pliers and pull out. Take half of the new seal, put alittle grease on the surface that contacts the crank (both halves). My seal had a small flexible plastic tab to insert between the block and the seal to protect the outside of the new seal during installation. Then slide the new seal in, seat it evenly. Put the new half in the cap, put a small drop of a good quality RTV on each end of one half of the new seal. Reinstall the main cap and torque the bolts.
Todd
Todd
Todd
Todd
Something else you might want to try, Valvoline MaxLife High Mileage. Did wonders for me. I'm not a big believer in stop leak products, they thicken the hell out of oil and make it sludgy. Especially not a fan of Lucas products. Some may feel different, but besides their fuel products, I feel like they are snake oil.
I put regular dino Penzoil in mine and it started leaking at the rear main. I had to add some synthetic b/c that's all I had it I don't know if it made it worse but drained it all and changed to all Penzoil again (that's what was on sale at the parts store) and added a bottle of Lucas per my mechanics recommendation. It has all but stopped now but I wonder if I hadn't used Penzoil with it's "cleaning agents" if I wouldn't have a leak at all to begin with. I won't use it next time for sure.
