Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
My Fabrication of 55 Panel Inner fenders
Old 04-23-2015, 09:21 PM
gerrymoe's Avatar
gerrymoe gerrymoe is offline
gerrymoe has a very good reputation on FTE.gerrymoe has a very good reputation on FTE.gerrymoe has a very good reputation on FTE.
Click the image to open in full size.
I don't have pictiures of the whole process, I am poor with taking pictures and I never had a camera that took pictures that would transfer over until after I was done with these, so here is what I have.
I am a retired sheet metal worker so I have access to a power brake.
I made these out of 16 ga cold rolled steel. I had replaced the firewall on my panel and put a volare front clip which necessitated new inner fenders.
__________________
Old 04-23-2015, 09:30 PM
gerrymoe's Avatar
4 Ft pc of z bar I made than fabbed brackets for mounting of the inner fender to air deflector
Inside of the fender well at connection of inner fender to air deflector, I used weld nuts thru out
Inside of engine compartment showing inner fender connection to air deflector
__________________
Old 04-23-2015, 09:47 PM
gerrymoe's Avatar
4 ft pc of j bar I fabbed to make the fire wall brackets to mount the inner fenders
Inside the wheel well where the inner fender mounts to the firewall. Formed the j bar to my desired shape, used weld nuts to secure the inner fender to the brackets and plug welded the bracket to the firewall
Inside the engine compartment showing the connection to the firewall. All holes are elongated to give me some adjustment forward and back.
I am seriously considering powdercoating these if I can get close to my color.
__________________
Old 04-24-2015, 03:31 AM
Jeeeppy Jeeeppy is offline
Jeeeppy is starting off with a positive reputation.
Looking nice, what are two aluminium bottles on fire wall for?
Old 04-24-2015, 06:12 AM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
They look AWESOME. I would like to see a shot of the whole fender..........
__________________
1956 F100
Old 04-24-2015, 09:43 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to all
bjmayberry2
Really Nice work! How did you determine where to make your bends?
__________________
BJ Mayberry
Old Guy with Trucks
54, 56 F100s & 56 Ford panel
All works in progress
Old 04-24-2015, 10:25 AM
gerrymoe's Avatar
The two bottles are my master cylinder remote reservoirs.
The bends were patterned after the original bends with some mods to acommodate the volare clip and flat firewall. The top 90 degree brake line was the first layout line, I call it the baseline, everything works off a baseline and a 90 degree line. From the baseline all other actual length lines are worked from there. The end point was determined by plumbing up from the wheel side of the frame straight up to the firewall and air deflector. With those points established I was able to layout the contour of the frame and upper a-arm cut out. This was all done on a pc of 1/8 hard cardboard they use on pallets that go between cans and made a pattern, this way I was able to trim and fit.
I will go out later and try and get a picture of the whole view, my camera skills are not that good tho.
__________________
Old 04-24-2015, 10:43 AM
gerrymoe's Avatar
One other point. I established the brake lines on the air deflector and firewall first. Than I fabbed the mounting brackets, installed them,, than layed out the bend lines using the tools I acquired durring my career. I used a plasma cutter, 4" grinder with cutting wheels, left and right wiss snips, die grinders and polishing wheels to de burr the edges.
__________________
Old 04-24-2015, 12:20 PM
gerrymoe's Avatar
Short of pulling the motor out this is the best I can do with my ability and camera, using my phone
__________________
Old 04-24-2015, 03:04 PM
Steve Bennett Steve Bennett is offline
Steve Bennett is starting off with a positive reputation.
Those look fantastic!! I also have the Volare clip, so I modified my original inner fenders. Yours look much neater. I'm sure you could do a brisk side business building those for us who have limited sheet metal skills (or tools). I am now building a 1954 Victoria to go with my 1954 F-100. You have inspired me to attempt to build my own inner fenders since after market is practically non-existent for this car. Thanks, Steve
Old 04-24-2015, 08:31 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to behold
Those look real nice...I modified some stainless steel inner fenders from Midfifty and wished I had something a little easier to work with while I was doing it.
Old 04-24-2015, 09:01 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss has a good reputation on FTE.drptop70ss has a good reputation on FTE.drptop70ss has a good reputation on FTE.
Excellent job, super clean work. The beading looks great!
Old 04-24-2015, 09:19 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Nice work!!!
Thanks for taking the time to post the pics and share this with us.
Bobby
__________________
...Someday our foes may win...
...but NOT today!!
1949 F1, 500ci Caddy
1967 Jeepster Commando
1994 Harley Road King
Old 04-25-2015, 07:01 AM
TonyB55's Avatar
TonyB55 TonyB55 is offline
TonyB55 is starting off with a positive reputation.
That's a first-class job! The cross-brake you added is a nice visual touch, as well as providing the intended stiffening.
How are you going to finish them? I would be tempted to chrome plate them.
__________________
Tony B. Brucatosvs.com
New Hill, NC
1950 F1
My 1950 F1 "Fordified" build thread
Old 04-25-2015, 07:31 AM
jniolon's Avatar
jniolon jniolon is offline
jniolon is a splendid one to beholdjniolon is a splendid one to beholdjniolon is a splendid one to beholdjniolon is a splendid one to beholdjniolon is a splendid one to beholdjniolon is a splendid one to beholdjniolon is a splendid one to behold
GM
Really REALLY nice work... I think you've had a lttle practice in front of the break
johy
__________________
my stuff.....
jniolon.classicpickup.com
Similar Threads
46 ford front cab to frame metal mitch47F 1947 and Older Ford Trucks 4 04-22-2015 12:17 PM
Selling a 1965 F-250 Camper Special chadsta 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-10-2015 06:59 PM
New custom trailer nitro3421 6.7L Power Stroke Diesel 12 01-06-2015 05:35 AM
Body Work, Check them rockers and cab corners tonym17 1999 - 2003 7.3L Power Stroke Diesel 4 01-01-2015 08:21 AM
Spotted: Built 2011+ converted Excursion ExploringNH Excursion - King of SUVs 14 12-31-2014 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
