A/C always on in the floor vents
If the selector switch is in a position other than "off", the blower motor runs. Lowest fan setting the fan will idle. That's just how it is. If you put the selector on defrost, and you're getting significant airflow to your feet, then you have a problem with the selector.
But ford has no "fan off" selection for the fan If you're on a/c, the fan will idle to continue flow through the hvac box.
PaulC
1997-2006 Expedition & Navigator
08-24-2004 08:39 PM
