Horn relay yes or no?
Old 04-23-2015, 07:47 AM
vanspeed's Avatar
vanspeed
vanspeed is offline
Did the 48 F-1's come with a horn relay from the factory? My new wiring harness from Sacramento vintage ford wires directly to the horn. My truck has an old relay on the inside driver fender well in front of the radiator. Some I have asked said they didn't have one, same say they did.
Old 04-23-2015, 08:01 AM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
If you have the single horn mounted next to the radiator, the wiring connects directly to the horn. There is no relay. The dual horns used on the '51-'52 trucks had a relay.
Old 04-23-2015, 08:45 AM
3twinridges's Avatar
3twinridges
3twinridges is offline
With no relay do the headlight wires also hit the top of the horn instead of the relay?
Old 04-26-2015, 09:59 AM
Flat Ernie's Avatar
Flat Ernie
Flat Ernie is offline
It's easy to wire in a relay, and smart too. Horns draw a fair bit of current. If you've switched to 12V, the standard cube relays are generally good for 30A - enough even if you're running your 6V horns on double the current! They sound good and loud too!!
Old 04-26-2015, 04:35 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Double the voltage, but half the current. My '50 F-6 had no relay but I'm installing one. I only want minimal current going through the horn button contacts.
Old 04-27-2015, 06:19 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
FAA-13853-A .. 6V Horn Relay / 1948/55 trucks.
Pic: Scroll down to 13853. Parts catalog makes no mention of the number of horns used with the relay.
Old 04-27-2015, 12:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The shop manual gives more detail
Old 04-28-2015, 07:54 AM
Flat Ernie's Avatar
Flat Ernie
Actually, if your resistance stays the same (ie - you don't change your horn), double the voltage also doubles the current. Ohm's law: I = V/R
Using 15 amps as indicated in Ross' post above, we can work this backwards to find the approximate resistance of the horns:
R = V/I or 6/15 = 0.4
Plugging that back into the original formula but with 12V, we get:
I = V/R or 12/0.4 = 30 amps
Old 04-28-2015, 11:00 AM
Mixer man's Avatar
Mixer man
Excellent! I stand corrected. That explains why you can get a voltage reading with a DMM, but yet cannot pass any current through corroded contact points.
Old 04-28-2015, 12:50 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
And now I wonder why all this time we've heard that a 6 volt system has to have heavier gauge wires because the current is double that of a 12 volt system when in fact, it is exactly half that of a 12 volt system. Can anyone explain this?
Here's Ohm's Law:
Ohm's Law
Old 04-28-2015, 09:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Joe, that is true when you are dealing with lights, where whether or not it's 6 or 12 v, the Wattage is the same. Because wattage is VxI. True for some other accessories, too.
Old 04-28-2015, 10:51 PM
49 Merc P/U's Avatar
49 Merc P/U
49 Merc P/U is offline
I hate to disagree but double the voltage equals half the current. It all equates to wattage - Volts x Amps = Watts. That is why 12 volt wiring is half the size of 6 volt, and 220 volts amperage is half the amperage of 120 volts.
Bruce
Old 04-28-2015, 11:07 PM
49 Merc P/U
I should also have added that you should always use a horn relay to minimize the current draw on the horn button contacts. The same goes for any high current draw, headlights etc. If you look at what Detroit does today they run almost every thing in light gauge wiring and use a relay to handle the higher current flow.
Old 04-29-2015, 10:00 AM
Flat Ernie's Avatar
Flat Ernie
Here's Ohm's Law:
Ohm's Law
You have heavier gauge wire to reduce resistance.
Bruce
It depends - AC is different than DC, but ohms law is pretty clear (and doesn't universally apply to AC). In DC circuits, double the voltage = double the current (all else being equal).
What is confusing is that a 6V heater motor and a 12V heater motor will draw about the same current if driven by the designed voltage. If you run a 6V heater motor on 12V, it will spin twice as fast and use twice the current. Wattage doesn't really come into play because you're comparing two different systems...
To further confusing things - anything with a coil is subject to magnetic inductance as well - so while Ohm's law works, it's not useful for exact numbers out of the equation. The principles still apply, but it's not a true direct relationship necessarily. This is why motors don't play by the same rules as light bulbs.
Old 04-29-2015, 08:14 PM
Jolly Roger Joe
Yes. That makes perfect sense. Thanks.
Quick Reply: Horn relay yes or no?
