1990 F150 running very rough
My '90 F150 4x4 is running very rough, jerking as i drive. Can hear somewhat of a ticking noise almost like a lifter. Every now and then it will snap out of it and drive normal. When having problem, poor acceleration and very little horsepower for a 351. Replaced plugs, wires, and fuel filter. Performs like this weather I use front tank, or rear tank so I dont think it is a fuel pump. Please advise, cannot seem to figure this out.
I would start with checking out the EGR valve and sensor and all pipeing for the emmisions. If there is a hole in any of the emmisions pipeing it can sound like a lifter ticking or a bearing going out. If there is a problem eith the EGR valve it can cause the syptoms that you are describing. After that then start looking into the air pump.
You might want to get the codes read if you don't have a code reader.
Good luck
Good luck
Thedonk
12-21-2023 08:56 PM
KLONDON
16
10-05-2016 04:15 PM
Boss F150
40
07-18-2016 07:31 AM
1918ALF
11-08-2015 02:20 PM
