I have a 2007 F150 It will stall out when I go over a speed bump. It has happened several times and getting worse. No codes stored. It will also skip between 40 and 50 mph. Any Ideas?
We used to have that with carburetors (float bounce) but not fuel injection. Only thing I can think of is a loose wire or wire connector. I would check all the grounds under the hood, especially the one down low on the firewall.
