Speedo Bezel Gasket
Speedo Bezel Gasket
Any tips on what glue to use to get the gasket to stick to the bezel?
My bezel is chrome.
I was hoping that I could loosen the bezel and install the gasket without unplugging everything and pulling it all the way out, but it looks like that's what I am going to have to do.
Good time to get my new gauges, turn signal switch, and deal with the sloppy shifter at the same time.
My bezel is chrome.
Unless you have a longer than normal speedo cable you will have to disconnect it to move the gage panel forward. Once that cable is disconnected you should be able to move it forward enough to install the gasket. I would put a towel or blanket on the steering column as the edge of that panel can be sharp and likes to scrape paint. Disconnect battery cables also at least the positive side as there can be power at the back of that gage panel without the key being on. Better safe than sorry. Some of the ones I have taken apart still have some tape on the backside of the gasket holding in place to the housing also. Im not sure if that is from the factory or a previous owner. It looks like a type of scotch tape but probably any quality tape will work as long as it will stick to rubber.
Scotch tape was used on the backs of the turn signal and high beam lens so that wouldn't surprise me.
I had said rubber cement but it's really contact cement. I've had this for about 20 years and still works like new. I bought it at Ernst Hardware for $2.32 plus tax, whatever that was at the time. I don't think Ernst has been in business for a while. Sounds like they went out of business in 1996 so sometime before that. Lol. Wow!!
http://en.wikipedia.org/wiki/Ernst_Home_Centers
It's hard to get a close-up of this but it says
"High strength bonds, no clamps needed. For plastic laminates, metal, wood, leather, linoleum, tile, rubber and fabric."
Here's Amazon's current offering.
It's an option, anyway. Works great. Just a "Dap 'll do ya".
No kidding, it's still almost 3/4's full. Comes with an applicator inside the cap but it's a little big for the seal - and why I use a toothpick.
66merc100
04-28-2019 07:27 AM
