How to unclog A/C condensate drain?
Old 04-22-2015, 01:30 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
Recently I noticed some water on passenger side floor (not antifreeze ). I am suspecting of a clogged A/C drain hose . Any suggestion as to the location of drain hose and how to do the task . Thanks
Old 04-23-2015, 06:52 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The drain is going to be at the very bottom of the AC plenum, usually directly under the evaporator core. Crawl under there and look for a plastic nipple, sometimes with a 90° elbow/hose, that comes through the firewall. It's usually buried up behind exhaust shields and can be tough to see sometimes.
A shot or two of compressed air with an air nozzle (you may need a nozzle extension, possibly "customized" for this) will usually clean it out. Stay clear or you may get soaked when doing this.
Old 04-23-2015, 06:59 AM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
projectSH089,
Thank you
Old 04-25-2015, 11:24 AM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
I wish I did get wet , I would have considered that as a confirmation of "problem solved " . I inserted approx. 10 in long wire ( no dirt built up) , gave few blasts with 80 psi compressed air .
My problem continues . I did a test drive (5 mile) with my manual Heating/Cooling system OFF and did not see any dampness (where passenger side floor meets firewall) . Second test (another 5 mile) with "Heater On" . This time I did see the dampness .
Fluid soaked paper towel did not help much to identify the fluid ( lack of color and smell) , but I have to withdraw my earlier statement about antifreeze , it could be a leaking heater . Radiator level is OK for now . So far the leak occurred while A/C was on and heater was on , I did not see the leak with Heating /Cooling OFF position.
Any suggestion to further diagnose the leak ?
Thanks
Note:
MageBeowulf
12-30-2011 01:58 PM
reel_gator
2004 - 2008 F150
03-15-2008 05:50 AM
amphicar770
07-30-2005 10:02 PM
rap1
06-12-2003 09:30 PM
Mil1ion
01-16-2002 01:20 PM
Quick Reply: How to unclog A/C condensate drain?
