Oil pressure gauge driving me crazy
04-22-2015, 12:10 PM
on
Can someone please help me with whats the best low pressure oil gauge out there and where to install the gauge to read the pressure from? I am really tired of the dancing gauge in the dash and want an actual reading! Any help would be appreciated. Thanks
04-22-2015, 12:28 PM
Have you tried cleaning the connection to the oil sensor or replacing the sensor
04-22-2015, 12:37 PM
on
I'm not really intrested in Dixon the dash one at all bec it's useless, I want one to actually read real time pressure. So I don't really want to waste time messing with the dash gauge
04-22-2015, 12:39 PM
Then get a electric autometer and put it the the OEM location on the top of the hpop res
04-22-2015, 12:45 PM
on
So do I put it in the same port as the dash one? How should I hook the wires up? And will a gauge that goes up to 100 psi work?
04-22-2015, 12:47 PM
Yes.
You won't use the factory wires. You'll run new ones
0-100 will be plenty
04-22-2015, 12:50 PM
on
Also, what should I be looking for in terms of pressures? Like idling, highway, OP temps?
And thanks for the help
04-22-2015, 12:56 PM
Up to tem you could see as low as 7-10 at idle and at driving speed 50-70 depending on pump condition
04-22-2015, 01:31 PM
on
so if im getting something rather low while im driving, then it would most likely mean that i have a bad pump then if im understanding correctly?
04-22-2015, 01:47 PM
on
04-22-2015, 03:05 PM
Just my .02 but I wouldn't use a glow shift
04-22-2015, 03:49 PM
on
Why do u say not to use them, just curious?
04-22-2015, 04:37 PM
They don't have the best record for reliability
04-22-2015, 04:44 PM
Sunpro is good. They are a part of snap-on
04-22-2015, 04:53 PM
Quote:
Originally Posted by
fordpride
X2^^^^^ I have them in my truck, and I question their accuracy.
