Help...Manifold to Up-Pipe Bolts Siezed.
They go right to sleep when ya flip them over...
After using hammers, chisels, scrapers and finally 4000psi rotating 0* tip to remove all the loose rust - a coat of Rustoleum 'rusty metal' primer was applied and allowed to cure.
Then, a healthy coat of Rustoleum oil-based enamel over that.
The manifolds were cleaned and VHT flameproof 2000* paint was applied (also up- pipe collector).
It turned out nice!
It turned out nice!
I'm just worried about what else I'm not going to be able to get out. I suppose if there's ever a good time to take the engine out it's now in the spring, when I won't need the truck. I have a 2,000lb stand and a 4,000lb cherry picker ready to go with the new oil pan and a ton of other parts. I guess I should just man up and do it. The engine has never been out in 13 years and 135,000 miles. It's gonna suck.
Ugh.
Ugh.
It's not as bad as you think. I've wrestled a few rustbelt truck engines and it's never been as bad as I thought it was gonna be. Think about it, the TC bolts, engine to trans bolts, etc won't be rusty. I've never had trouble with motor mount bolts either. Now stuff like trans cooler lines to radiator? Plan to improvise (cut tubing and splice together at reassembly with hose) or buy new lines and maybe radiator. If you decide to do it, I'll think about what other little pitfalls ya might encounter.
Get that new oil pan Line-X'd and have it waiting.
135k miles is a baby!!!! Well worth the investment!
Not really, especially since I'd have to take my fender flares off. (Screwed into the fender.)
Never heard that before, but frig it,I'll try it.
#29
#30
