battery group/size
I have never figured what the heck group size was either. I look at post location, 525 CCA or more if you like and have been using least expensive battery that I could find. Replaced one in my 66 a couple years back that had been in it for 9 years. I think it is a waste of money to buy expensive batterys.
John
John
A group 27F is the correct battery for your truck. The "F" designation gives the battery the reversed terminal locations ((+) closest to the solenoid) so the battery cables don't have to cross. A group 27 will fit, but the (-) terminal will be near the solenoid.
The battery group refers to the physical size of the battery, not the electrical capacity. Just because the group number is a larger number doesn't indicate the battery is physically larger or has higher amp hour capacity.
R-22F was the smallest battery, R-24F was the medium size. Neither should be used with an FE engine.
Slick-rides
05-22-2017 04:05 PM
