Intermittent miss/fuel pressure issue?
OK well got both valve cover off and all connectors looked good so I took cyl 5 injector and swapped it to cyl 1 and ran buzz test again injector was still way quiter than the rest. So two injectors down. Which leads me to my next question. With 253xxx miles should I bite the bullet and throw 8 baby swamps in or just replace those 2 bad ones? For those with baby swamps did you notice a difference in power a lot?
No, checking the solenoid resistance is to see if the solenoid is the problem. It is easier and cheaper to replace a solenoid than an injector.
If the bad buzz followed the injector when you transplanted it, and the solenoid ohms out acceptably, then I would expect the injector is bad. Call Jim at Rosewood and talk to him about it; he is an injector expert.
As far as new injectors go, you probably won't go wrong with Baby Swamps- I haven't seen much about them in the way of bad. However, Jim at Rosewood seems to have the best reputation on this particular forum. Every time someone recommends Rosewood, there's 5-8 people jumping behind them with a recommendation of their own.
I also have Rosewood injectors. So maybe I'm biased. But if you call him, he'll probably have more useful information for you. Rosewood Diesel Shop
SaintITC
21
06-16-2015 02:26 PM
SidecarFlip
11-15-2010 09:15 AM
