Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
5.4L part time misfire
Old 04-21-2015, 07:10 PM
00F350XL's Avatar
00F350XL 00F350XL is offline
00F350XL is starting off with a positive reputation.
Ruby Shirlee RUBY_R1 iamrubyshirlee
Unhappy 5.4L part time misfire
ok please bear with me I have a 2000 f350 5.4 liter I recently fixed a misfire in cylinder 1 since then every morning the truck runs perfectly fine however at night when I leave work around 6 o'clock the truck has a misfire again I stopped pullover pull the spark plug out put the spark plug back in and it runs perfectly fine all over again please help me I don't know if this matters but when I replace the spark plug I only replaced one and not all 8 same thing with the new coil pack I don't see how that could cause this but if anyone knows better please tell me
Old 04-22-2015, 01:46 AM
Psyclopse's Avatar
Psyclopse Psyclopse is offline
Psyclopse has a good reputation on FTE.Psyclopse has a good reputation on FTE.Psyclopse has a good reputation on FTE.
To clarify, you're getting this same issue when a new plug and/or a new COP is used?
Are you reusing the same rubber boot on the end of the COP? If so, the boot may be defective.
Also, you could have an intermittent connection going on with the COP connector.
__________________
Joey
2000 Excursion Limited V10
1999 F-250 Super Duty V8
Pic: My '99 & my dad's F-350 Crew
Old 04-22-2015, 02:27 AM
Thor'sHammer Thor'sHammer is offline
Thor'sHammer is starting off with a positive reputation.
I would replace every plug boot. Every time I had a misfire on my old '99 V10 F350 it was always attributed to a plug boot deteriorating.
__________________
'05 F350 CCLB DRW 6.0L 5R110-New truck!!!!
'95 F250 SCLB 4X4 7.3L E4OD Lifted, bagged-Sold
'99 F350 CCSB 4X4 6.8L 4R100 Lifted-Sold
'94 F150 RCLB 4X4 4.9L M5OD Lifted 10"-Sold
Old 04-22-2015, 06:43 AM
00F350XL's Avatar
no I replace the coil and the spark plug this past weekend and I just pulled the same one up and put it back together and then around 6 o'clock when I leave work the issue continues but again I just pull it out and put it back in and it goes away
Old 04-22-2015, 06:44 AM
00F350XL's Avatar
Quote:
the plug boot is brand new though on this one coil
Old 04-22-2015, 07:59 AM
00F350XL's Avatar
Heres my baby giving me the headache
Click the image to open in full size.
Old 04-22-2015, 08:35 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant future
How many miles are on your engine? What brand plug and COP are being used? Are you applying die-electric grease to the boot? Anti-Sieze to the plug threads? Torquing the plugs properly? Is it the cylinder under the wiper cowl?
Below is a link for a possible solution if you are getting water or moisture between the plug and COP. I willd be applying the o-ring method next time around for my plug swap.
http://www.ford-trucks.com/forums/11...s-the-fix.html
__________________
99 F250 CCSB V10 4x4 Lots of money into it.
Old 04-22-2015, 08:46 AM
00F350XL's Avatar
Well I dont know if this is even the stock motor. The truck used to belong to BNSF, then my father in law bought it. I am the 3rd owner. The tach says 340,000 miles.
The brand of coil is Master something, not MasterCraft though, i was looking at the box this morning, I check on break in about 2 hours. As for plug itself, I'll have to get back with that one too. I am applying the anti seize and die-electric grease. Is there an amount i should use vs not use? Also, no the cylinder is #1 and its the front left one.
Old 04-22-2015, 08:51 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to behold
I'd go back to the COP and make sure it "snaps" or locks properly on the wire harness. Others have seen the same thing when not fully locked on.
And to Bently's point, check for moisture in the plug cylinder hole. A leaky intake manifold will allow enough coolant into the plug hole to help ground out the COP.
__________________
Bob and better half
As my brother reminds me regularly... "Life is not a spectator sport."
2007 F-250, PSD, SW, CC, LB, 2 WD, 85k, coolant filter, DashBoss, 1999 Expedition 5.4 322k plus, 32' CrossRoads CrossTerrain 5th wheel Toy Hauler, 24' Chaparral Villain lll 598 ci
redford's Avatar
redford redford is offline
redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.
Exactly where on the spark plug did you apply anti-seize compound? How much?
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
FTE Guidelines
Old 04-22-2015, 08:52 AM
Master Pro? O'Reillys house brand. I would recommend motorcraft for these parts. Time and again people use inferior/cheaper parts and end up regretting it.
__________________
Old 04-22-2015, 09:57 AM
00F350XL's Avatar
r2millers: Yes sir the plug is dry when i pull it from the motor so i dont THINK any moisure is affecting it but i may be wrong. How do i know for sure?
redford: I applied the compound to the threads on the plug, all the way around the threads.
Bently Coop: YES SIR it was a Master Pro, I just went with it, because it was right by my house.
Old 04-22-2015, 10:30 AM
00F350XL's Avatar
Im going to O'rielly now to get the Borg Warner upgraded unit. Sorry i probably spelled that wrong
Old 04-22-2015, 11:42 AM
jjlrrw jjlrrw is offline
jjlrrw is starting off with a positive reputation.
Sounds like you recently fixed a misfire in the #1 cylinder, is this new misfire setting the CEL and you are always reading cylinder #1? On my 4.6L I was getting random misfires under load the CEL would flash but not always set a code, I was able to use a OBD reader that would display "pending" codes and found out it was random. I finally changed the POS two piece spark plugs and everything has been good the past 25k miles.
Old 04-22-2015, 11:56 AM
00F350XL's Avatar
What do you mean two piece spark plug?
Similar Threads
Misfire F-350 Went724 Super Duty & Heavy Duty 1 09-10-2014 05:53 AM
5.4 random misfire HappyRanger 1997 - 2003 F150 5 02-21-2014 01:06 AM
5.4 V8 Misfiring AGAIN! Titus136 Expedition & Navigator 5 04-04-2011 08:02 PM
Fouled Spark Plugs jayhawker6 1997 - 2003 F150 2 08-08-2006 04:50 PM
1997 F150 Misfire Please Help patton 1997 - 2003 F150 2 04-19-2005 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
