Modular V10 (6.8l)
Funky sound from the engine when I hit the gas/shift down...
Old 04-21-2015, 05:47 PM
IttyBittyX's Avatar
IttyBittyX
IttyBittyX is offline
Guys, for the last year or so, when I hit the gas pedal and it shifts down (you know, to get it to pick up speed faster), it makes a funky sound once I let go of the gas pedal.
Almost like a sucking sound (yeah, it's prolly telling me it just sucked down a quart but seriously...)
I have recorded it and I can do it again and post it here if necessary. However, not sure how clear it will be to others considering background noise. I hear it clearly but then, I'm used to my engine.
The more it speeds up or the longer I hold the gas down, the louder that noise seems to be when I let go of the pedal.
Thanks
Old 04-22-2015, 06:42 PM
V10man's Avatar
V10man
V10man is offline
I wonder if you are hearing the fan.
Old 04-22-2015, 11:50 PM
IttyBittyX's Avatar
IttyBittyX
I'm guessing it's not. Sounds weird, it's like a sucking (a bit high pitched...) sound. Sounds very weird I think.
Old 04-25-2015, 08:05 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
Sounds like a vacuum leak to me
Denny
Old 04-25-2015, 06:17 PM
IttyBittyX's Avatar
IttyBittyX
Denny
That (sound wise) sounds like it could be right.
Is that bad?
What IS it?
Should I try to get a decent recording of it?
Thanks
Old 04-25-2015, 06:36 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
Just start checking all vacuum lines, start with the PCV valve.
Denny
Old 04-25-2015, 06:42 PM
IttyBittyX's Avatar
IttyBittyX
I'm helpless so someone else has to do it or I'll have to take it to a service place
Is this something that can be bad for the truck and what can it cause?
Thanks
Old 04-25-2015, 06:50 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
It can cause the motor to run lean and over time it will harm it. I would have it checked before something happens.
Denny
Old 04-25-2015, 06:55 PM
IttyBittyX's Avatar
IttyBittyX
I will. THanks
Old 04-26-2015, 05:40 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Maybe it's the back pressure from the turbochargers when the throttle closes.. Totally normal.
What boost level are you running?
Old 04-26-2015, 05:46 AM
IttyBittyX's Avatar
IttyBittyX
V10, no computer...??
It didn't use to sound like this though. Been doing it for the last year. Didn't have the money to have it looked at...
Old 04-26-2015, 05:47 AM
IttyBittyX's Avatar
IttyBittyX
I will try to get a sound clip for you guys. I hear it clearly but again, I know my engine so I notice it. You guys may not but I'll give it a shot.
Old 04-26-2015, 07:26 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
I was just messing with ya. If you had a Turbo V10, everyone here would have been drooling all over you for dyno sheets/pics/test drives lol..
Old 04-28-2015, 05:32 PM
IttyBittyX's Avatar
IttyBittyX
Sorry I couldn't respond earlier but I had trouble accessing the forum.
I WAS wondering if I had features I didn't know about. I thought I didn't but hey, when you're not good at this stuff, things aren't that obvious
Greenie326
2015 - 2020 F150
10-09-2020 05:13 PM
sammie0126
01-23-2013 07:34 AM
driller tom
6.7L Power Stroke Diesel
16
07-24-2010 11:03 AM
pukemon
2004 - 2008 F150
18
05-02-2007 09:56 PM
cadriver
1983 - 2012 Ranger & B-Series
34
04-06-2007 08:56 AM
Quick Reply: Funky sound from the engine when I hit the gas/shift down...
