crazy? engine swap idea
I can't be the first to have thought of this, but here we go.
The new coyote engines are popping up everywhere and wouldn't take much to save up for one. They now have a zf5 that can bolt to one meaning perfect tranny for our trucks. The wiring harness is unbelievably easy to work with.
Three things come to mind that will be difficulties in making this happen.
1. Engine mounts. should be easy enough to fab something here so I'll go on to the next question.
2. Fuel system. Not sure if the stock pumps would be adequate for feeding the engine. It may be a better idea to swap to one large tank and install a newer f150 pump or maybe just upgrade both in tank pumps. I don't know which direction I'd go with that one.
3. Radiator. My core support is rotten anyway so I'd be in there soon enough, but could a newer f150 radiator be made to fit with a homemade core support so adequate cooling is achieved or would a factory support and radiator be good enough?
Seems with some time and effort, and a lot of money, this could result in a really nice daily driver that would get better mileage and make more power than any of the other options on our trucks.
If I think I can make this work, I'll start saving soon and potentially dive in next summer. I'd love to make it happen though.
on
It would be cool for sure but It won't getting any better milage than a built up 5.0 or 5.8 with the same trans and axle gearing, it takes a certain amount of energy to more a vehicle so engine type really doesn't matter. Proof of that is in the average fuel milage returned by modern trucks which really isn't significantly better than what these old trucks got and is definitely not better than what is achieved when a 5.0 or 5.8 is upgraded to comparable output levels.
What would be the truck that you put it in?
The newer 5.0 although it has a better tranny gearing for mileage, the truck weighs considerably more and shows 21 Mpg.
Obviously mileage wouldn't be my main reasoning for doing a swap like this.
obviously the logical option is a 5.8 but sometimes it's fun to be different.
I think if I had a 5.8 already, I wouldn't even be thinking about it. I'm one of the few people who doesn't like my 4.9. It's reliable, that's about all I can say about it.
You must really love your truck to invest that kind of time and money.
As far as the swap, what you listed for concerns, only the fuel is of concern.
I would either upgrade both the pumps to a newer pump I knew could take the variable voltage output of the computer, me block off the return line. Or convert to a return system. There's no reason to switch to a single tank.
Engine frame mounts are easy, radiator is of no concern because there's plenty of room for the new style, and probably not a big deal to use the old style, I'm sure it's not that much small if it is at all.
Making it work is easy. There's a lot of room under the hood. You just need time and money.
It's either a 5000 dollar project for a coyote or a $500 investment for a 351... Doesn't seem too tricky to me.
It is literally a weekend job if you bought a parts truck.
I'd prefer to do a 351 with headers a cam and some head work.
after I clear out my garage, I might just have to make a clean spot to start building one.
