2014 F350XL Jump Seat to Center Console Swap?
on
Hi Everyone-
I'm planning on swapping my jump seat for a flow through center console in my 2014 F350XL 4x4 Crew Cab. I realize the flow through venting will not work unless I change or modify the duct work. But my main question is related to the wiring for the power inverter. Does anyone know if the wiring harness/connector for the inverter is already under my vinyl matt? Remember this is an XL built not a XLT or higher build. I'm hoping all of the wiring harnesses are the same for all of the build levels and that the connector will already be there ready for me to connect to?
Thanks in advance for you knowledge and help!
RRRAVEN
RRRAVEN
