F350 2WD Steering Wheel Play...How Much Play Is Acceptable?
My 1997 F350 2WD has 134k miles and what I consider to be a lot of steering wheel play. I can feel the spline with the pitman arm has some side-to-side play when I have someone steer the wheel (when I put my hand on the box while I'm under the truck). At the steering wheel, this translates to 1-2" of radial motion in each direction. I'd like to eliminate, or at least minimize this slop because the truck can be a handful to keep straight, especially when towing a trailer on the highway. I daily drive an IS300 so that kind of play in my truck feels ridiculously sloppy.
I understand Ford trucks don't have the most wonderful steering even by truck standards but I want to get the best I can, but need to know if replacing parts is going to fix my issue, or if the issue is just my perception.
There's about a billion threads on what steering box to use, but I'd like to know how much steering wheel play I can expect to eliminate with a replacement box. I don't expect sports car response, but will a replacement gearbox get me back to at least a tight center spot while driving?
Here is what I did with my truck. Scroll down to 4th or 5th post.
It made a huge difference with my truck and I am happy with the results. It is a bit expensive, but I am hoping it will last a long time.
I am sure you have already but check and make sure you don't have play in the steering shaft joints, tie rods, etc.
Maybe because I'm on my phone I'm not seeing a link anywhere. I'll check back tonight.
I just ordered new tie rods (inner and outer) as well as a remanufactured box. It's a 4 bolt box redone by a company whose name started with an L that had some happy recommendations in other threads. I just decided to dump all the old parts and start fresh. I'll post a follow-up when I get it all installed and if I think about it, a video of the steering before and after.
Rachel Moody
15
01-16-2017 11:51 AM
mustang68s
07-22-2010 02:28 PM
dale gribble
19
08-14-2005 09:16 AM
