installing intake manifold
Old 04-20-2015, 09:02 PM
usuallybowtie's Avatar
usuallybowtie
usuallybowtie is offline
Getting ready to lower the intake onto my rebuilt 360. Everything I've ever read and done in regards to chevy v8's says to forget about the block wall (China wall) gaskets and just lay a bead of rtv down instead. Does this apply to FE engines as well? The heads and deck surfaces were milled a few thousandths to clean them up if that matters. The cork gaskets I have are pretty thick. Don't want any poor fitment or leaks. As always, thanks in advance
Jb
Old 04-20-2015, 10:08 PM
KO1960's Avatar
KO1960
KO1960 is offline
Yes. Bag the cork gaskets and use silicone. Setting the dizzy is a good way to get the intake placed.
Old 04-21-2015, 12:32 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
Jb
For end seals I have had best luck with Ford TA-31 sealant. Actually made for diesels. Works best I have found
Old 04-21-2015, 09:08 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
I used the cork gasket + a thin layer of prematex # 2 no leaks (yet)
Old 04-22-2015, 12:36 AM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
I have always used the cork gaskets with never an issue. Just three weeks ago I used a bead of silicone and had a vacuum leak for the first time in the back. Go figure and since the intake was not going to come off for a third time it has been fun trying to fill the invisible, to me, gap in the back.
Old 06-21-2015, 01:39 PM
gumshoe's Avatar
gumshoe
gumshoe is offline
go to fordfe.com theres a big post on this subject, everything you need to know about installing the intake .
Old 06-30-2015, 02:04 PM
Dot Heton's Avatar
Dot Heton
Dot Heton is offline
I was going to start a thread like this but let's keep this one going.
My main concern is the weight and setting the intake down straight onto the gaskets. The cork gets really slippery and slips around on occasion.
I'd like to get that grey Ford diesel silicone, is it available anywhere besides the dealer?
Old 06-30-2015, 07:41 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
Not sure about getting the ford stuff anywhere but the dealer. I know I paid about $25 for a little tube of it from the dealer. I used it a few times building my last motor but I really don't like the way comes out. It's like real tacky right away. I believe it is good stuff though. For my intake I used the cork just because the Fel Pro stuff had adhesive on it. I was very impressed with how well that cork stuck to the block....normally the cork is all over the place.
Old 06-30-2015, 08:56 PM
Dot Heton's Avatar
Dot Heton
Hmmm...... I bought a felpro set, when I get home I'll check if it has cork adhesive. I think I'm going to buy permatex gray, I read a couple of good reviews on it.
Old 06-30-2015, 10:17 PM
KO1960's Avatar
KO1960
KO1960 is offline
Amazon sells it, and everything else in the world. I used permatex gasket maker for my intake. Good stuff.
Old 06-30-2015, 10:27 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Where else? Amazon
Amazon.com: MOTORCRAFT TA31: Automotive Amazon.com: MOTORCRAFT TA31: Automotive
The cork end seals with adhesive look tempting but they may vary a bit in thickness. I tried them out and then laid the intake for a trial fit. The intake sat too high and may not have come down enough when torquing. That might leave me a water port gap and definitely a mis-alignment where the head and intake meet. So I used the TA-31.
Good luck as I have had three failures already and will be going for #4 to seal the intake.
Old 07-01-2015, 07:26 AM
69cj's Avatar
69cj
69cj is offline
Permatex Ultra Black is designed for contact with oil.
Old 07-01-2015, 03:02 PM
Dot Heton's Avatar
Dot Heton
My fel-pro gasket set did not come with the adhesive so I might leave the cork out. I was going to order the TA-31 sealant from that link but there is 8 bucks shipping, that makes it up there with the dealership. I'll try permatex ultra black or grey, I have to do some research and decide which one.
Old 07-01-2015, 04:30 PM
69cj's Avatar
69cj
69cj is offline
The grey was recommended to me for the third member and the ultra black for the intake.
Old 07-01-2015, 09:06 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
I've used the Ultrain Blue, Black, Grey all for different purposes. Kind of whatever I have at the time and they all seem to work well with oil. I've used the blue and the black on 2 diff Mustangs rears I have and both are leak free and hold Mobil and Amsoil.
Quick Reply: installing intake manifold
